Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Jan 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Whirlpool Duet Front Load Washing Machine is showing a F28 error. What does that mean?
  • Anonymous Jan 20, 2013
    ive tried that resetting of the machine by unplugging it etc, but when i press the start button, i hear a faint click of the door lock and it doesnt even start?
Anonymous
Level 3:
  • Master 1,998 Answers
  • Posted on Jan 16, 2011
Anonymous
Master
Level 3:
Answers
1998
Questions
0
Helped
620524
Points
5972
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  • Press the Pause/Cancel/Stop button twice to clear the display.
  • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation when our chat has concluded Thanks again Rick
  • Richard Roth
    Level 3:
    Top Expert:
    • Whirlpool Master 9,472 Answers
    Richard Roth
    Whirlpool Master
    Level 3:
    Top Expert:
    Answers
    9472
    Questions
    Helped
    2627448
    Points
    28464
    Resolution: Error code F28 = Serial Communication Error. Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below. In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
    • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
    Note: If the Hard Reset does not work, there may be an internal failure with the washer, that requires service.
    Nicole Washburn
    Level 1:
    New Friend:
    • Contributor 1 Answer
    • Posted on Aug 27, 2018
    Nicole Washburn
    Contributor
    Level 1:
    New Friend:
    Answers
    Questions
    0
    Helped
    10070
    Points
    We had an f26 code looked that up tightened the locking mechanism and now we have an f28 code.... what do I do now
    What does f23 error mean?
    Display shows an error code - Front-load washer ' Whirlpool ...
    https://www.whirlpool.com/...error-code...w...
    Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
    What does error code f23 flashing mean on a Whirlpool ...
    I have an F28 error what is wrong
    As far as I know F28 error code means - SERIAL COMMUNICATIONS ERROR/MOTOR CONTROL UNIT ERROR. Caused by either a communications problem between the Central Control Unit and Motor Control Unit, or Motor Control Unit internal failure.
    1helpful
    It starts and then stops and then F28 flashes
    http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
    Not good! Probably motor control board or motor or wiring harness from control board to motor.
    This leads to a Kenmore Video
    Whirlpool, Maytag, Kenmore. Same machine different name different trim.
    Whirlpool Duet f28 YouTube
    What does F28 mean.
    F28 is a SERIAL COMMUNICATION ERROR.
    1helpful
    Kenmore H2 PLUS reads F--28 code what does this mean?
    The error code F28 means one or both of these parts are bad.
    Motor Control Unit (8540135)
    Microcomputer Machine Control Unit (8540788)
    It would be a good idea to order both, as both components have been problematic for error code F28
    If you find either the MCU or the CCU(Microcomputer Machine Control Unit) fixed it.
    Here's the online repair manual for your
    Whirlpool Duet Sport, but its identical to your HE2.
    Give it time to download.
    On page# 4-20 it shows how to access your MCU.
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
    2helpful
    Code f28
    Hi, the error code F28 means one or both of these parts are bad.
    • Motor Control Unit (8540135)
    • Microcomputer Machine Control Unit (8540788)
    It would be a good idea to order both, as both components have been problematic for error code F28. If you find either the MCU or the CCU(Microcomputer Machine Control Unit) fixed it.
    3helpful
    I washed a large load in our Whirlpood Duet Washing Machine and it stopped with a flashing F28 code. I unplugged it for 5 minutes and it still will not run a cycle without stopping with a flashing F28...
    You can download the online repair manual in the below link
    4helpful
    2answers
    F28 CODE
    Whirlpool Duet
    2helpful
    What id a F28 code on a whirlpool duet washer
    Can be the machine control or the motor control here is a link to the Repair manual....
    What does f28 error mean
    Your camera does not support the aperture range, maybe.
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
