SOURCE: roxio creator has problem and will shutdown
If you haven't already, you might want to uninstall then reinstall the program. Sometimes a program will seem to install correctly when it hasn't or, become corrupt over time. If you do this and continue to experience the same issues with the program then you may need to move onto troubleshoot the issue further.
SOURCE: TRYING TO INSTALL FROM BOUGHT DISC ROXIO CREATOR 9 WILL NOT
Instead, for *FREE*, access http://www.MajorGeeks.com
and search for "AShampoo Burning 6", download it, and install it.
It is FREE software for burning CD/DVDs.
SOURCE: c language for 64-bit operating system for windows vista ultimate
just type this line in google there are many option download it
SOURCE: ROXIO CREATOR 2011 SPECIAL EDITION
I have window 7 and Roxio Creator 2011 Pro will not install at all.
SOURCE: I have a Hewlwtt Packard
http://www.roxio.com/enu/products/creator/suite/system-requirements.html
these are the requirements for to run this program ...If that message appears..it means that you do not have them all ...and in this case it may be an issue like having an AMD CPU instead of a Intel one ...or the CPU is too weak ....Even if ..I checked the laptop's specs..and it doesnt seam so ..
you may try to see if it isnt a issue with the operating system ...maybe needed a 32 operating instead of a 64 ..or the other way around..cause it seams that your laptop has at least a 2G cpu and more than 1G ram ..so it may be one of the other requiring be the issue..
check the video and the software needed...player s..internet connection ..and all that ..from teh list ..and try again after that ..
