Kirby Shampooer Shampoo Hose G3 Ultimate Diamond Vacuum Logo
Posted on Jan 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Don't know how to assemble the shampoo attchment of my Kirby. i bought it used seeral yers ago.
Roger Potts
Level 3:
  • Master 694 Answers
  • Posted on Jan 16, 2011
Roger Potts
Master
Level 3:
Answers
694
Questions
0
Helped
220417
Points
1873
The following link leads to an instruction clip for this. It's the fourth clip down.
http://www.kirby.com/Portals/0/videos.html
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Shampoo furniture
I have had a Kirby for over 20 years and yes you can shampoo your furniture. You do it just as you would your stairs or as if you were spot cleaning. There is really nothing to it.
3helpful
2answers
Having trouble shampooing
I found this on a website. Hope it helps others...
by Mainelyvacs in: Kirby
  • First a short explanation of how the Kirby shampoo system works: Kirby uses a “Dry Foam” type of shampoo. Basically, it spreads a shampoo foam solution on the surface of your carpet. This foam needs to stay on the surface of the carpet until it is completely dry (usually 1 to 2 hours depending on temperature and humidity) As the foam dries, it soaks up grease and dirt. You then vacuum the carpet and up comes the shampoo residue along with the absorbed dirt and grease. It does a very good job on the surface but will not extract stains from the bottom of the carpet or carpet pad. Several other brands such as Electrolux, Hoover and Koblenz make Carpet Cleaning machines that use the same system.
    So, you’ve read your manual, you’ve removed the carpet cleaning nozzle and the bag assembly from your Kirby, you’ve installed your shampoo tank and carpet shampooing nozzle tray and you start to shampoo but all you get on your carpet is a puddle of soapy water and no foam. Here’s a few things to look for:
  • Make sure you are using a Dry Foam Shampoo(preferably Kirby) and NOT an extraction shampoo, the Rug Doctor shampoo you had left over from your last rental will not work.
  • Make sure you have the correct mixture. If you are using Kirby Dry foam shampoo you simply fill the tank with water and put a tank cap full of shampoo in with the water. You can use other brands of “Dry Foam” shampoo, but the mixture ratio may be different, so read the label first.
  • Don’t reuse last year’s leftover mixture, it’s probably no good.
  • Make sure a family member didn’t pour any leftover mixture back into the empty shampoo bottle - further diluting a mixture will not produce any foam.
  • Don’t use shampoo that’s seen extreme temperatures.
  • Check the tank and make sure that the sponge filter is in place and if it is in place that it is not deteriorated. The sponge filter is located under the tank at the point where you attach the tank to the hole that you removed the bag assembly from.
  • Check the hose that runs from the tank to the nozzle. It should have a screen in the end that attaches to the tank (older models had a cloth screen with a metal retainer, models after 1989 have a 1 piece metal and plastic screen.
2helpful
How to shampoo stairs
HERE is the manual
When rating my solution rate the clarity of the explanation NOT whatever you like Kirby stair shampoo system. I do not believe this is the way to shampoo either but this is not me who designed it. Will get the job done but it is a lot of scrubbing and rubbing.
Good Luck
Rocky
Kirby
machine will not come on
2helpful
2answers
Carpet shampoo system
MY FIRST QUESTION IS WHAT BRAND OF SHAMPOO ARE YOU USING??? KIRBY IS NOTED FOR REQUIRING ONLY, KIRBY SHAMPOO. PART OF THE REASON IS THAT THEY HAVE A UNIQUE FORMULA THAT WORKS SPECIFICALLY WITH THE KIRBY.
THE OTHER POSSIBILITY IS THE DISPENSER IS PLUGGED AND NEEDS A REAL GOOD CLEANING. ALSO, WHEN APPLYING THE FOAM TO THE CARPET, YOU NEED TO GO REALLY, REALLY SLOW.
THE NARROW BAND OF SUDS DOES INDICATE YOU MAY BE MOVING THE DISPENSER TOO FAST. GOOD LUCK.
Shampoo attachment on Kirby G3d.
Has been a while since you posted the question. I have made an Online Kirby shampooer manual. See it it helps
For the first time, I tried using my Kirby Sentria shampoo attachment. I've lost the manual but found instructions online for making the swap from regular vac to shampoo-er and got it all assembled. The...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=638285
Generic problem for all Vacuums
Posted by MHicks on Jun 01, 2008
For the first time, I tried using my Kirby Sentra shampoo attachment. I've lost the manual but found instructions online for making the swap from regular vac to shampoo-er and got it all assembled. The foam laid down just fine; however, when I run the vac back over the foam to pick it up, there is not a stitch of water showing up in the tray. First I thought maybe it was bc I hadn't put that much of the foam/water onto the carpet, but 12 hours later, the carpet is still wet in spots. Clearly my assembly wasn't 100% but I don't know how to figure out what's wrong. Help!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In a case like this I would contact the factory, by the sounds of things you did everything right but it is a dry foam shampoo and some moisture will get into the carpet. I will list the Kirby factory phone 3 listed below for your assistance with this problem. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/Contact Us by Phone
United States and Canada: 1-800-494-8586
Between the hours of 8 a.m. – 5 p.m. (EST)
Monday - Friday
United Kingdom: 0800-328-1247
Europe: 00-800-5472-9272
South Africa: 0800-203-222
Contact Us by Email
Complete the online Form to Submit Your Comments or Questions
Contact Us by Fax United States and Canada: 216-529-6146
Contact Us by Mail
Consumer Relations Department
The Kirby Company
1920 West 114th Street
Cleveland, OH 44102
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 01, 2008 • Vacuums
1helpful
3answers
I have lost My Kirby G5 Manual
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=11561&thid=539967
Posted by Marie1231 on Apr 23, 2008
Kirby G5 Bagged Upright Vacuum
I need to know how to use the attachments that came with the Kirby. I know how to use the shampoo/vacuum, but not the other attachments or the upholstery cleaner. Does anyone have any idea?
1st, you need to un-hook the lever @ the top of the Kirby head, dial off the belt from the Kirby Vacuum Head using the Kirby emblem in the front of the vacuum, that also serves as a hook/spoon to dial the belt off the fan pulley. Once you have removed the vacuum head you now hook up the attachment hose to use the attachments by locking the attachment hose to the top lever. All regular Kirby attachment will fix on the attachment hose end including the spin brush if you have one with your Kirby --- using the Kirby Shampoo spray the soiled area and use the spin brush to agitate the carpet and or upholstery, try not to use to much water. If you have a Kirby shampooer – use the recovery tank on the exhaust port of the Kirby (this means that the cloth/paper bag needs to come off and install the clear recovery tank. Please refer to the Kirby owners manual for any type of trouble shooting that you might need – or please feel free to contact your local vacuum dealer in the yellow pages or contact your Kirby factory manufacturer listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
