Https://www.easeus.com has recovery programs.
First off, I assume that you have a USB Hard drive that use between computers. One big mistake people make when moving a USB device from the computer is they fail to use the EJECT method. For example, when you go to File Explorer and select a drive from the "This PC" whereby all attached devices are listed and you are able to make a section from the icons showing on the screen. Assume you bring up a USB Drive, use the drive for some reason, and then when finished, you simply PULL the USB drive out by hand. NO! Use the eject format to disconnect the USB drive so you do not create STATIC Charge. Down at the lower right side of the computer screen is a ^. Hit that and Icons come up. An Icon that looks like a USB device (may be upper left) is the safety removal tool. The hard disc you have may have been statically charged and thus the FORMAT may have been damaged. Without a format, the drive is not capable of being read. Repair programs have the ability to read sectors and lift data that was lost to a Format problem.
SOURCE: simpletech external hard drive 320gb not starting
try this ;;make shur that the drive is set''' to slave drive and that your other drive is setup to run with a slave drive then you shuold be able to get your data off if'''if not it will not let you'' you can e-mail me back if you need more info''''on this i will try to help ya as much as i can ' i work with slave drive all the time'' i have one computer that has three hard drives on it and they all have windows on them'i can load from or the other'''and i can get stuff off each one when i need it'''now some stuff you can not get'' it will say you got it but like some program will not work by doing this a lot will but their is a few that will not work'''' my e-mail is '' [email protected] thanks'' my name is james !!
SOURCE: Data recovery from Portable Hard Disk
There are tools that will undelete & unformat you drive.
look here for free one.
http://www.softwarepatch.com/software/filerecovery.html
and here for a selection.http://www.freebyte.com/filediskutils/
finally this one is great but costs.
http://www.easeus.com/
SOURCE: Hi This is Srinivasa reddy,
1. Right
click on I drive and select Properties
2. Click
on the Security tab
3. Click
Advanced
4. Within
the advanced window select your administrator account and choose to
apply onto “This folder, subfolders, and files” click ok
5. Then
check the box at the bottom of this window “Replace permission entries
on all child objects with entries shown here……”
SOURCE: not able to copy /delete
take a look at the properties..by right click on its icon on my computer ..and see if it is not set to read only ...or right protected...cause this may cause the data not to be able to be changed or formatted ..If on properties the read only is ticked ..just clear the case ..and let it empty ...after that try to format it again in Fat32
SOURCE: how to recover data from corrupted hard drive?
Hi, liub97.
In your case, it is recommended to use this data recovery tool to recover as much data as possible. If you are Mac OS X user, go to this Mac hard drive recovery software.
Then follow the procedure to reformat your corrupted hard drive. Mycomputer -> Computer Management -> Storage-> Disk Management . Note: you can also opt for a third-party formatting tool.
Things are not over, after formatting, retry the program to see if more data can be recovered as you know a simple format option won't erase data permanently.
Best regards.
