2000 Toyota ECHO Logo
Anonymous Posted on Jan 16, 2011
Continued battery drain and high pitched noise when car started
Duane Wong
Level 3:
  • Toyota Master 6,826 Answers
  • Posted on Jan 16, 2011
Duane Wong
Toyota Master
Level 3:
Answers
6826
Questions
6
Helped
2860308
Points
20233
Maybe the alternator is bad. A high pitched whine could mean that the alternator is not working properly.
One can test, by removing the belt to the alternator and running the engine and seeing if the whine goes away.
  • Duane Wong
    Duane Wong Jan 16, 2011
    Or one could bench test the alternator and see if it whines.
High pitch alarm sound when vehicle on or off
try disconnecting the battery and reconnecting
K5 blazer starter
If you did not drain the fuel all the way or put a stabilizer in the fuel then you have gummed up lines for one thing. The other noises are not really concerning.
Hi last week a high pitched noise started on my 02 hse. the noise seems to becoming from the rear of the vehicle, it is a continuous noise, I recently had the fuel pump replaced, could this have anything...
When you turn the key to position II, does the noise start then? This would be the fuel pump. If it is making a noticeable noise while driving, then you should get whoever fitted it to check it over. If it failed, your car would stop immediately.
2004 trailblazer ext high beam headlights wont turn off and the relay makes high pitched noise
Need to check the ground path on the squealing relay. A poor ground will cause this condition.
Screeching noise, especially w/heat on
SOUNDS LIKE YOUR A/C COMPRESSOR IS DEFECTIVE. WITH HEAT ON COMPRESSOR CYCLES FOR LUBRICATION
3answers
Engine will not crank, battery and starter have both been tested and pass, hear a high pitched spinning noise when turning the key over
The high pitched spinning sound you hear is the starter bendex trying to engage the flywheel. The starter may check out ok, but the bendex is turning but coming out. The starter will need replaced.
My 2004 Chevy Trailblazer is making a bizaar noise when I start it up. It's starts as a high pitch squeal then drops to a lower pitch squeal then ends in kind of a grind. Thought it was a slipping belt but...
Hi Eabyrd05.
It's possible that you have a Starter or Flywheel/Flex-plate issue. Your starter Bendix may not be completely disengaging from the flywheel like it should. I would take it to a mechanic that you trust and have them pull the starter and look at both the Flywheel/Flex-plate, Starter Bendix and solenoid. Hope this helps.
My car wont start, fuel pump problem?
fast high pitched noise? never seen or heard of this, done 100's of belts, this noise is caused by a belt being adjusted to tight, belts just break. do you have fuel pressure, what engine do u have?
1helpful
Very hot alternator after just replacing and a high pitch squeel
THE ALTERNATOR CAN GO OUT DUE TO A WEAK OR BAD BATTERY CAUSING IT TO OVERCHARGE TRYING TO KEEP UP WITH DEMAND ON THE ELECTRICAL SYSTEM. IT WILL HAVE A HIGH PITCH NOISE WHILE CHARGING AT A HIGH RATE AND FINALLY IT TO WILL GO BAD.
HAVE THE BATTERY TESTED AND CHECK THE CHARGE RATE AT THE ALTERNATOR AND AT THE BATTERY.
How would you know if a start signal is reaching starter solenoid? new starter , battery is good some thing is killing volts before car starts
When your solenoid receives a voltage signal from the ignition you can hear a "click" when it engages. If your engine turns over like it wants to start or you hear a clicking or a buzzing under the hood your starter works. If you turn your lights on after starting and they work it's not electrical at all. If you try to start it and you hear a high pitch whining type of noise and then your battery dies, then the teeth on your flywheel are gone.  The starter will just spin there and it will drain your battery with a quickness.
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
