Replace start relay. but do not replace same brand ptc . it always bad. use supco.
i feel u pain
i try to help u
but say thank to me frist
are u ready?
let,s go go go. where ?
ome minutes
oh i get it
you tube type how to replace start relay
http://www.youtube.com/watch?v=f8EmTaKNhas
good luck
i am a hvac
i am go to sleep
good night
i like jjoking
see u next time
The manual reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit
completely. Then keep both the doors open. Wait for 24 hours. All the ice
collected on the coils and in the freezer section will get melted.
Clean the water from the sections. Then Connect the power cord of the unit to
main power outlet after 24 hours/.Then set the temperature to normal in both
fridge and freezer section. It will take approx 4 to 6 hours for your refrigerator to regain its regular cooling/ freezing .So after 4 to 6 hours check , Is the refrigerator cooling properly or is it taking time or temp is dropping once you open close door. If this problems are not noticed, then reset procedure has helped.------- But if same problem is noticed after reset procedure is followed, then you can get the compressor checked.
This should help.
Thanks.Helpmech.
