SOURCE: My 03 Wrangler shakes only at 45 mph
My Death Wobble started immediately after I installed a set of Coil Spring Spacers (to lift 1.75 inches). Turned out, the DW was because while changing the height, I also lowered the CASTER angle in the front end. So, to fix it, I could have purchased a set of eccentric bolts for $50+. Instead I went out and purchased a piece of 1.5 inch flat bar for $10 from OSH. I cut out 4 1.5 inch squares. Then i drilled 7/16 inch holes centerline, but close to one side (in exactly the same place) on all for squares. I then removed the lower control arm bolts, nuts and washers. I installed these square offset washers I made so the front axle would be pushed forward (to increase the Caster angle). The toe setting changed a bit, so I reset them to about 1/8 inch toe in. After driving my Jeep, I noticed there is no more DW. The steering wheel was off center, but after 3 attempts, I have that perfectly centered. I have every intension of having the alignment checked, but not till after I find the new tires I want. If anyone is interested, I can draw out and photograph the cure and send it to you. My e-mail is bb62471(at)yahoo(dot)com.
SOURCE: My corolla is shaking when it drives up to 70 miles
Possible causes of this are, bad tires, tie rod ends worn out, < inner or outer > ball joints, rack and pinion slack. Main causes are generaly found in front end components and if tires are good for certain then have it looked at as soon as you can, < it could lead to dangerous situation >.
SOURCE: 1998 toyota corolla shakes before 2 rpm, check engine lights up
Not sure what is causing it, but it sounds like you're running on 3 cyllinders. Check plugs, wires, timing . timing belt may have jumped, bad injector, low fuel pressure.
SOURCE: my front end shakes when i hit a bump at 50 mph, the front tires
could be a bent rim ? have you changed the universal joints? how about the tie rods and stabilizer bar
Testimonial: "thank you very much, i will do this first thing. i have had several people look at it , and of course they have told me it was not the tie rods,i knew"
