Well, let's see what service the unit has had in its 6 or 7 years of working--
When was the Humidifying pad last changed?
These usually have to be changed every year-- to get good performance from the humidifier...
So-- Have you looked inside the large door?-- what does the pad look like?
When the furnace is running, you should be able to open the humidifier door, and look in, (Air should be sucking INTO the door as you open it, if the unit is properly mounted in the return air duct work..) and if the humidistat is calling -- the motor should be turning the big wheel, and moisture is being added, as the wet surface is exposed to the air returning to the furnace. What do you see?
There is also a water sump, filled by a float valve-- is that valve admitting water into the sump?
Is the pad wicking up this water, and rotating into the air stream?
That pad is easily changed-- your hard ware store probably has replacement pads-- they can be sewn back on to the wheel, after removing the old one.
Let us know if we can help further-
Mack B
