IPhone setting:*
- Auto-Lock: 1 Minute;*
- Passcode Lock: On, require passcode immediately, after 15 min or 4 hours etc;*
- Network: Turn 3G Off
Scenario 1: Home screen is active with screen on*
1. Press power button for seconds until asked to '"slide to power off"
2. Slide to power off
3. press power button to turn on iPhone
4.*When asked to enter passcode, touch the "Cancel" key, then slide to unlock
5. bypassed passcode
Scenario 2:*
1. On the screen of being asked to enter passcode, press power button for seconds until asked to '"slide to power off"
2.*Slide to power off
4.*When asked to enter passcode, DO NOT touch any key on the screen,
5. Slide to power off
6. press power button to turn on iPhone
7.*When asked to enter passcode, touch the "Cancel" key on the right bottom corner, then slide to unlock
8. bypassed passcode
Notes:
1. When Network setting changes to Enable 3G: ON, "3G" signal shows up, passcode CANNOT be passed through
Go to a underground parking lot or a lift where 3G signal is weak, when
3G signal switches to "E" (Edge), passcode CAN be passed through
following above steps
2. When no 3G or Edge signal, above steps don't work
Conclusion:
Seems passcode security is related to network status
Possible security hole under Edge
PLEASE CANANYBODY HELPPPPP MEEEEE!!!
iPhone setting:*
Scenario 2:*
4.*When asked to enter passcode, DO NOT touch any key on the screen, press power button for seconds until asked to '"slide to power off"
Notes:
1. When Network setting changes to Enable 3G: ON, “3G” signal shows up, passcode CANNOT be passed through
Go to a underground parking lot or a lift where 3G signal is weak, when 3G signal switches to “E” (Edge), passcode CAN be passed through following above steps
2. When no 3G or Edge signal, above steps don’t work
Conclusion:
You can put your iPhone into recovery mode then exit it, it may be fixed. I know the easiest way to enter and exit iPhone recovery mode is to use a free and safe tool called Tenorshare ReiBoot. It is able to make it with one click.
SOURCE: i forgot my apple iphone
Try the Restore procedure from iTunes If you have problems. But first try the recovery procedure.
1.
Disconnect your iPhone cable but leave connected the other USB end to the computer.
2.
Turn
off your iPhone holding the Sleep/Wake button. The red slider bar
appears. Slide the bar and wait until the iPhone turns off. Or you could
hold the Sleep/Wake and Home buttons at the same time until the iPhone
turns off.
3.
While pressing and holding the Home button
connect the USB cable to your iPhone. It should power on. Hold the Home
button until you see the "Connect to iTunes" message. Open iTunes if
necessary. You should see the "iTunes detected an iPhone in recovery
mode..." alert screen.
Choose " Restore"
Here I just knew a professional iOS unlock tool named Joyoshare iPasscode Unlocker, which can help you remove lock screen in a few minutes when you forgot your iPhone passcode. It only takes 3 steps to unlock your passcode, even beginners can handle it easily. To know more details, you can visit its official site:https://www.joyoshare.com/ipasscode-unlo...
