SOURCE: Rainbow E Series Suction Problem
Being an E series some have a corrgated filter in the top, there is also a filter on the back. Could be a motor problem, not turning as fast as it should, in which case you will have to replace the motor. You might check, some had a 10 year warranty on the motor. If you are the original owner and only have had it 5 years, then it may be covered.
SOURCE: Rainbow aqua mate II instructions
You have the vacuum and the basin, you put them together just like when you vacuum but don't put water in the basin. There is a large white container that comes with the shampooer. you fill that up with water and then you place the vacuum cleaner and the basin on top of that. Now you will need the water hose (not the one that has the gas pump hadle). Hook that in the same spot that you do for vacuuming. Then you take the shampooing handle( it will have a trigger and a little white bottle and some tubes hooked to it) the one end of it hooks to the water hose and the other end hooks to the wands. There are 2 wands that come with your shampooer. At the end of those the shampooer head will be attached. There are two separate tubes there is a thick tube ( there two tubes fused together) and a thin tube, they hook to the large white container that you fill with water. Just look and you will see where they go. Then there is a tube that hooks to the shampooer head at the bottom. The you take the little bottle and fill it with your shampoo. You should have gotten some clips to hool onto your hose so that you can keep the tubes attached to it so they aren't in the way. You should be set. I hope I helped.
SOURCE: Rainbow e series Canister vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=661549
Posted by tinyrose on Jun 10, 2008
I am looking for a repair manual for this vacuum. Just stopped working and will not turn on. Can you tell me where to get a manual? Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The best way to get a Rainbow E Series owner’s manual is to contact the Rainbow website and or factory and give them the model and serial # for the item and you may be able to download the manual from the website or the might have to mail it out to your home USPS. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
SOURCE: Rainbow Model e Series will not start. Where is the reset button on this vaccum?
There is no reset button on the canister. It may be a bad power switch, a power cord, or the button that presses in when you put the water basin in place may be bad - or the prong on the water basin that pushes that button in when you place the canister on the basin may be broken off.
SOURCE: When I turned on the vacuum it started to smell
You did not say if the vacuum ran and started to stink after running for a while. If this is the case, it's usually time for new brushes and a motor cleanup.
