My xbox 360 slim don't connect in my home network, when i disconect the network lock that the only way that conect and my network don't reconigzed the network the xbox nither
1) Go to Settings 2) Select "System" to take you to the system settings menu 3) Highlight Network Settings and select it 4) Select Wireless Network to setup your wireless
For older Xbox 360 consoles:
1) Your will need an Xbox 360 Wireless Networking Adapter. Check online or your local stores to see if there is one available. 2) Once you have the adapter, simply hook it up to your xbox and follow the instructions at the top of this solution to setup your wireless through the xbox dashboard.
I'm going to assume that you are talking about the New Xbox 360 Slim that has wireless capabilities. You must go into your settings and go to the network settings. When you choose to connect wireless-ly, choose your routers signal, and if it has a passcode you must enter this in to connect to your router. If you are using the older "fatboy" xbox, you cannot connect to a wireless router unless you purchase the xbox wireless network adapter. Please note that you cannot use the wireless network on the new xbox slim if you have a network cable plugged into your console!
You need either a blue Ethernet cable to connect the Xbox to an internet outlet or a wireless router. If you use the wireless router, hook it up to your computer so it broadcasts a signal, then, depending on what Xbox you have, if its the new 360 slim you won't need a wireless adapter, you search for the signal, then connect it. If you don't have the 360 slim, then you need to buy a wireless adapter and it plugs into the back of the Xbox.
In order to connect your xbox 360 to the internet you are required to purchase the network adapter, unless you have a new Slim model. After purchasing the adapter, from the dashboard go to "my xbox" then scroll all the way to the right to "system settings" select that then select "network" connect to your network from that screen and you will be online.
I imagine you have bought the new slim Xbox 360? Did you use a HDMI cable to connect it to your TV or did you use the standard cable? If you used a standard AV cable ensure that you connected the red and white cables into the same AV input as the yellow video cable.
You need to have a wifi connexion at home that you can connect to. You will need the wep or wpa key ( a protection code for your network) that was programmed in your router so that you can connect to the network. If you do not have a router or a wireless connection at home, you can only connect with a network cable.
you will need a switch board (network board with multiple ports for with ethernet) and an internet conection. its best to have a router invilved with your modem and so it dosent overheat and shutdown. set it all up and plug you computer into the network board and the consel and you should be good. and make sure to conedt the internet cable in the network to. you need a internet conection to access files from your pc
I believe the X-Box does NOT have Wifi built in?
(sic)Surprisingly, the Xbox 360 doesn't have wireless networking built in. If you don?t fancy using the wired Ethernet method, you can invest in a wireless networking adapter. Microsoft has its own adapter specifically designed for the Xbox 360, but third-party Wifi-certified devices will work just as well.(sic) From the below site.
http://72.14.253.104/search?q=cache:d7LlkY7Zo1sJ:www.vnunet.com/personal-computer-world/hardware/2147007/microsoft-xbox-360+xbox+360+wifi+is+built+in%3F&hl=en&ct=clnk&cd=2
So that may be ya problem?
