Its a problem of your battery. You need to buy a new battery for your camera. If its is new then the battery charger need to clean & try. Let me know the battery age please.Its a problem of your battery. You need to buy a new battery for your camera. If its is new then the battery charger need to clean & try. Let me know the battery age please.
You can't post conmments that contain an email address.
It could possibly be the battery or the charger itself.Try purchasing the charger it self.Use the old battery to see if it will charge it. If it does not charge you may have to purchase a new battery.as well.
I'm sorry that the Camera is displaying the error message. "TURN THE POWER OFF AND ON AGAIN" displays on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset. Please follow the below steps to perform a power reset.
·Turn off the camera. ·Remove the battery pack. ·Press and hold the power button for 30 seconds. ·Allow the camera to remain without power for 60 seconds. ·Reinsert the battery pack. ·Turn on the camera.
Also try initializing the Camera if you're able to access the Menu items on the Camera. The Initialize option will be available underSetup or Main settings Sub Menus.
If the issue persists again, service is required. Pleaseclick hearto locate the service center near your area.
Thanks for understanding. Please let me know if your require any clarifications.
Depending on the Camera you have, on the camera it self, access the menu and under your connections, make sure you have it set to "ask on connection" or select the option you would like to use when you plug the camera in.
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Well the first thing I would do is recommend you send your unit in for service as you may end up doing more harm then good. You can call and get free estimates on what this may cost. If you need any further assistance or help locating a service center let me know. Thanks, lee
Open battery chamber and look to see if batteries have leaked into the camera. If you do not see signs of battery acid inside then the fault might be caused by shutter flexiboard being faulty.
In either case it is not economical to repair : you will be quoted $ 200 to sort this out ( new shutter flexiboard costs $100 ! ).
