Question about E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop
I have an emachine t2984 with a factory video card. I want to upgrade my video card but read that there are no expansion slots (PCI-e) to do this. Does this mean i need to buy a new computer to play video games? Please help.
    New Friend:
  • 23 Answers
A video card can use AGP, PCI, and PCI-E slots. If it is a older model it should have either AGP or PCI ( Mainly AGP ). Many video cards are still available for these slots.
If you want to play the top games of these day though, most of the time these slots will not work games like this. They COULD work, but the best cards of today is PCI-E. Good luck and do not forget to rate :)
Posted on Jan 15, 2011
6ya staff
SOURCE:
Pci card slot
Since you have a PCI-e expansion slot any graphics card that is PCI-e interface will work, it all depends on what you do with your computer if you game on it then you'll want a more expensive card, if you don't do gaming then you can get by with a less expensive card. Just remember that just because you put in a very expensive graphics card doesn't mean you'll be able to play all the new games at high settings because the rest of you system is quite old and will not be able to keep up with an expensive graphics card it's what's called a bottle neck. Whether it be your processor and or your memory being the bottle neck in your case it would be both. So keeping all that in mind a low priced PCI-e graphics card would do just fine. Hope this helps
Aug 03, 2013 | eMachines D6419 PC Desktop
My son saved up and bought a Gateway SX2855-UB12P. We have upgraded to 8MB of RAM and now are looking to upgrade the video card which currently is a PCI Express x16 Graphics. Given his machine is a en
Hope you mean upgraded ram to 8 GB 8 mb is not much ram to run a computer.
To upgrade your computer's graphics card, unfortunately you can't just simply purchase a card and install it to your computer. Before purchasing a card, you must first confirm what is compatible with your motherboard. Graphics cards use either AGP or PCI Express technology. Many older computers use AGP. AGP cards can vary in version and bandwidth, whereas PCI Express cards can vary based on their lane . Moreover, the card itself is not your only consideration when looking to upgrade your computer's graphics. You must also consider the strength of your computer's power supply as well, since most newer cards use a lot of power. Download, install and run SiSoftware's Sandra (see link Below) to find out information on your motherboard. http://download.cnet.com/SiSoftware-Sandra/3000-2086_4-10556571.html Click the "Mainboard Information" icon, then write down the information next to "Manufacturer" and "Model." Navigate to the motherboard manufacturer's website. If you are not sure of the website's URL, enter the manufacturer's name into a search engine to find the company's website. Go to the support page and enter your motherboard's model. Download the motherboard's manual or review the specifications. Search the manual or specifications for "Expansion slot," "AGP" or "PCI Express." If the expansion slot uses AGP, note the version (AGP comes in 1.0, 2.0 and 3.0), as well as the bandwidth (1x, 2x, 4x or 8x). If the expansion slot uses PCI Express, note the amount of lanes (x1, x4, x8 or x16). Search the manual or specifications for "Power," "PSU" or "Power Supply." Write down the power supply's voltage (3.3V, 5V or 12V) and amp rating (designated by "A"). Not all manufacturers list the amp rating in their documentation, so you may need to contact the manufacturer for more assistance. Compare the graphics card you want to buy to the motherboard's expansion slot. AGP cards won't work in motherboards using PCI Express, and vice versa. Similarly, AGP 3.0 cards won't work in motherboards using AGP 1.0. A PCI Express x8 card will not fit in a PCI Express x1 slot. Check the voltage and amperage of the video card to the voltage and amperage on your motherboard. A video card that requires a higher amp rating requires a powerful PSU. Hope this helps.
b>
Dec 24, 2012 | Computers & Internet
Expansion slota
eMachines Support > ET1331 desktop computer > Product Views > Rear View,
http://support.gateway.com/emachines/desktop/2009/emachines/et/ET1831/ET1831rv.shtml
The metal covers that have the Plus sign ( + ) holes, are Expansion Slot Covers.
Insert a flat tipped screwdriver blade in the + sign hole.
Insert the screwdriver blade horizontally, in the + sign hole, on the right side. ( ---- , not vertical I )
Gently bring the back of the screwdriver down.
This will make the metal slot cover, bend the small metal tab that is holding it.
Go to the + sign hole on the Left side. Do the same on the Left side as the above.
Bring the back of the screwdriver up.
Keep working the metal expansion slot cover back, and forth, until the two small metal tabs that are holding it in, break.
Remove the metal expansion slot cover.
Before you begin, ensure that the expansion slot cover you wish to remove, lines up with the wireless adapter card.
Have any questions concerning this, post in a Comment.
Jun 25, 2010 | E-Machines eMachines Refurbished EMA...
We have an emachine w3400 and need and new video card but don't know if it is PCI standard or PCI express how do i find out?
The eMachines W3400 desktop computer has an MSI MS-7145 motherboard.
(MSI = Micro Star International, Inc)
This is the MSI MS-7145 motherboard,
http://www.e4allupgraders.info/dir1/motherboards/socket754/msi7145.shtml
The MSI MS-7145 motherboard, has one PCI Express x16 expansion slot, which is used for a graphics card.
Viewing the bottom left of the photo, you will see three white PCI slots.
Right above them is a longer white slot.
This is a PCI Express x16, expansion slot.
Scrolling down to the subheading - Expansion Slots,
You will see - One PCI Express 16x slot, listed.
Should you require information in installing a PCI Express graphics card, or information on which PCI Express graphics card may fit your needs, state so in a Comment.
(Believe upper right of your page)
Jun 16, 2010 | E-Machines eMachines Desktop PC
Do mother boards pci and agp slots
If it's a motherboard from an T2984 eMachines then it has only PCI, no PCI-E or AGP.
Jun 04, 2010 | E-Machines eMachines Refurbished EMA...
Installing an mic geforce fx5200 128mb pci-e card on my emachines t3408, and it seems that the pci slots on my computer are reversed from the pins on the card. please help!
It seems to me that your computer has an AGP slot which is a much older type of interface. AGP is much older and they no longer use them.
From the model you posted, you have 1 AGP video card slot and 2 PCI expansion slots. there are some but very few companies that do make cards for PCI that will be much better than an emachine onboard video.
But your computer will not support PIC-E
Mar 01, 2010 | Palit Microsystems GeForce FX5200 Graphic...
Looking to upgrade my Emachine W3118 Graphics Card Need Help!
Yes if you have a PCI slot your can purchase many video cards with TV-out and S-video out. Do not PCI confused with PCI-E though. Thank you
Oct 15, 2009 | E-Machines eMachines Desktop PC
I going to buy a emachine et116107 today and i
That particular model has PCI-Express slot for optional upgrades. So if you decide to upgrade the graphics look for anything with a PCI-E label or PCI-Ex16. If you do get a new card make sure to disable the onboard graphics in the system BIOS prior to installing new card. Instructions can be found via google search
Oct 05, 2009 | eMachines ET1161-07 Desktop PC
Want to upgrade the video card but dont know where to start. are the three expansion slots at the bottom of the board used to expand drivers like the video?
Hi there.
Seeing as the graphics on that board are integrated Intel Extreme Graphics and the board does not have PCI Express or AGP slots then you can use one of the 3 PCI expansion slots to install a video card.
The largest PCI graphics card I've seen is a 512MB card and that was not cheap as the latest video slots are PCI Express.
It will however free up essential system memory which is always a good thing.
Regards
Jun 11, 2009 | Intel D845GVSR Motherboard
Can I upgrade my graphics card?
You could tell us you model number or look it up yourself on the e-machine website(Link provided below).  I do know that the PCIe x1 slot is only about an inch long. Maybe that is why you didn't see it?
http://www.emachines.com/support/product_support.html
Feb 15, 2009 | E-Machines eMachines Desktop PC
E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop Logo
167 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
