Sometimes the burner holes get clogged. I use a toothpick to clean out the holes.
Hope this helps.
I never even saw one of these babys. Wow what a stove. The simmer issue might be fixed by removing the knob and seeing if their is a minimum flame adjustment in the stem of the gas valve. The non lighting issue could be some sort of flame sensing device not recognizing the fire is lite, you could try holding in on the knob a little longer to allow the flame sensing device to pick up OR get a brush and clean around the ignitor. She sure is a beauty. The constant ticking is usually a stuck spark switch.
To find the one that you suspect is stuck you must remove a wire from each switch till you find that one
This video shows how to adjust flame:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
