Samsung Jet S8000  Cell Phone Logo
Posted on Jan 15, 2011
I have a samsung jet. when I tried to text someone today, nothing on the touch screen is doing what it should! the text is coming up as keypad,the keypad numbers are all in the wrong place,for example the 5 is 4 and the 9 is 7 please help it is an effect unusable debbie
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Jan 15, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
0
Helped
1690
Points
17
Basically ur qwerty kernel is all buggered. i suggest flashing the phone youll find a step by step guide via a search online. look for something like samsung s8000 flash guide?
My samsung jet mobiles touch screen is not working properly, when i click on one button on my screen it touches another button instead and therefore i am struggling to text messages with it, i have tried...
If you click one area on the screen and the phone selects another area then you might need to change the touch screen. I happened to me because I let my phone fall to the floor. I did the change for $30.
My samsung jet wont let me use half of the touch screen so i am unable to call, text, dial out, use the settings, alarm, games or anything ells any ideas?
The touch-screen actually may be broken.You might have a bug in the firmware, to test this you can do a factory restore/reset.
Whilst texting would like the keypad to be silent. phone is S8003 samsung jet.
Somewhere in the Settings should be an option called "Phone Sounds" or something similar. "Keypad" or "Touch" Sound should within this menu, and that should contain an option to mute.
2answers
Basically I just bought a Samsung Jet locked to Orange. The phone had been previously frozen by another owner it now is just phone freeze and tells me sim unavaible.there is an unfreeze code but I have...
You can get the correct Unfreeze Code and Instructions at here
http://www.superunlockcodes.com/samsung-jet/rs12wp9/ and Unfreeze Samsung Jet..........
Samsung Jet Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Samsung Jet mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung Jet mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
1 - Switch ON your Samsung Jet with a NOT ACCEPTED SIM Card.
2 - Samsung Jet will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung Jet shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung Jet.
3 - Compose : #0111*CODE#.
Feb 13, 2011 • Cell Phones
My Samsung Jet s8003 is giving me problems. Frequently when I touch one icon on the bottom of the screen icons say the keypad or phonebook or messages it fails to open. When i open the menu with the middle...
Hi , From the description of ur problem it is very clear that ur touch pad is not synchronizing up with the touch . To fix it u will have to reset the factory settings and u need a a code to do the same . I will give u the code and see if it works .one of these will work for sure
  • *2767*3855#
  • *#5239870*#
  • *#7092463*#
Note : don't forget take a backup of ur contacts and other important things that u can't afford to lose
1helpful
2answers
I have the same issue as you, sometimes the phone does work correctly but and lets me select settings to recalibrate, but after a few moments the problem reoccurs, no matter where I tap on the screen only the icons down the left hand side of the phone activate !!! Driving me mad !
7helpful
3answers
Dropped samsung jet touch screen not responding,
The touchscreen connector has come loose. It's a small flatcable which connects the digitizer (touch screen) with the pcb on the back of the screen. It's repairable, however you need to disassemble the complete phone. A great disassembly guide can be found here: http://www.formymobile.co.uk/jetdisassembly.php Good luck! :)
2answers
Texting issues
How can I send a Picture in a text message with the HTC Touch Phone
Touch screen buttons not working
Well i suggest you get a new full housing case ( cover + keypad , this should help if not try to take it to a phone shop . hope  i helped xxx
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
