I have a customers 1700, and it has a display that just shows a few dots, and now the USB and Parallel ports do not respond. I removed the suspected parts and checked for cold solder joints and pinched wires, no help. What are the part numbers for the display and the PCB that contains the parallel port? Any other idea's since I can't see any information?
Larry D Peterson
Bangor Office Machines
The CP1700 LED was a problem for HP. This part is no longer available from HP. Machine will function fine without however when a problem occurs you won't have a clue what the machine is asking for....more than likely it will be asking for a specific printhead or cartridge.
This problem is not an issue in the Business Inkjet 2800. LED is much different
Inkworks
866-381-0541
The digital readout on the CP1700 is a problem. I have replaced mine now 4 times at a cost of $90 each time, and I'm going to have to do it again or get the new 2800. Just wonder if the 2800 is going to have the same defect.
Where can I get a new display for the HP cp1700 printer?
