Acer Aspire One Netbook Logo
Posted on Jan 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I want to connect my acer aspire notebook to my tv, how do i go about doing this?
Anonymous
Level 3:
  • Master 368 Answers
  • Posted on Jan 15, 2011
Anonymous
Master
Level 3:
Answers
368
Questions
0
Helped
131205
Points
1168
Alright didn't really know what acer model you have, but this is pretty easy, you can attach your Tv to either oneof the external source outlet on your acer and Press the FN button between your left ctrl and alt key. There should be a symbol in the F keys exm, (f1, f2 ) in which i believe acer is the F5 key... that looks like a laptop'a sqaure.... Press those two keys and depending if you have it hook up to the HDMI or VGA, just press until you find the correct port via vga/svideo/hdmi.
Acer aoa110 connect to tv
connect or pc with a HI-SPEED (HDMI) CABLE TO UR TV..AND PLUG IT IN TO HDMI..CONNECTION..MOSTLY ON THE SIDE OF THE TV..OR ON THE BACK...JUST LOOK AROUND......AND IT WILL WORK.. CHANGE UR AV SETTING ON UR TV...AND PC SCREEN WILL APPEAR ON UR TV SCREEN...'
CHEERS
2helpful
How do I connect Acer Aspire One to sony bravia tv?
Then use a VGA cable to connect to the PC IN on the TV.
How to see acer screen on tv
if your acer aspire has a TV out port then you just need to connect a cable from that to your TV, that is if your TV has an input port as well...
Hi i have an acer aspire one....i want to play movie through TV
I would recommend you s-video. I also have an Acer Aspire and s-video is working perfectly. you have to change the second monitor's resolution on your PC to the display and frequency of the TV. The most common configuration is 800x600 display with a 60mhtz refresh rate (frequency), and send the image through the additional monitor (your TV).
Not able to connect my Acer Aspire 4720Z notebook to TV
You will need to change the TV's input select to S-Video to view your notebooks display. Remember S-Video is just that, Video and no sound. You'll need to patch the audio in via Audio In input on the TV if you haven't already?
Hooking up to the tv, aspire one acer notebook???
hi there, try a 15 pin male vga to vga cable ...select vga mode on monitor
User acer aspire 4720 as monitor for playstation3 gaming console
what you need is a usb tv tuner for your laptop it is a device that allows you to plug tv cables into your computer for dvr and viewing funcionality
2answers
Can´t connect my laptop to tv monitor
Try lowering your screen resolution on the laptop first. (Right click on desktop > properties > settings tab > and move the bar to the left - try the lowest setting to start with
Acer Arspire 1642 WLMI does the vga output support tv out?
i dont think it has..you can then buy a VGA to RCA for the regulatr TV(should work for both the TVs)
an example is here
http://www.cablesnmor.com/vga-rca-cable.html
please info if u want more help,will be glad..regards
5answers
Downloading limewire
Go here and download it.... http://www.limewire.com/download/ then install it after you have saved it to your PC.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
