I have noticed the same thing. Occasionally, an email message will display normally in my Thunderbird inbox, but the body of the message will "disappear" when I try to forward it.
My Thunderbird program is set to send messages in plain text format, and that controls the way that messages are forwarded as well (even if they were originally composed in HTML). It works fine most of the time - but a small number of HTML messages "disappear" when forwarded. (I assume there's some problem with the original formatting of the message, or with the way that Thunderbird changes the HTML into plain text.)
I have found a work-around for the problem -- by changing the settings so that messages are sent (and forwarded) in HTML format. Here are the steps: * In Thunderbird, go to: Tools > Account settings * On the left side, scroll to the account in question, then select Composition & Addressing * Then on the right side, place a check mark in Compose messages in HTML format . * Click OK to close the account settings box.
After competing those steps, forwarded messages will retain their original HTML formatting, which should solve the "disappearing" problem.
And of course, you can change the account settings back and forth (between text and HTML composiition) whenever you like. So you could keep your account set to use plain text most of the time; and make the change only when you encounter a problematic HTML message.
try uninstalling all the yahoo messenger in your computer then restart the computer..then try installing the new yahoo messenger the 9.1 i think i forgot but its the new one...now if it srill doesnt work try calling yahoo messenger...
oh i can fix yah !!!!!!!!!!!!!! just go to the c:/ dir and click program files and click the messenger dir and you can see there the uninstaller !!!!!!!!!!! and if you are now uninstall the program and then go to the yahoo website and download the latest ym program ///////////the problem is there might be a corrupted files
first try windows update
if that don't work right down exactly what script it is then
click start then run type in msconfig
then a box will appear click on startup
then find the program click to remove restart computer then click don't show message again
Note that the large black box goes away when pushing buttons on the tv (ex: the black box will disappear to show the volume setting when changing the volume on the tv but it will cover the picture and the menu display of the dtv box).
This is caused by the closed caption setting of the television set NOT the captioning of the converter box. To fix this you must open your television's menu, find the ccd/closed caption option, and turn it off. This is a frustrating problem as when most people are told to shut off the captioning they try to do so at the box.
Normal dtv box captioning will appear as a small text box at the bottom of the screen as you would expect - not as a giant black rectangle that covers most of the screen. If you do want to shut this off too you will find that you can't do it through the usual menu options (the menu will only allow changes to font, color etc.) - there should be a ccd button on the remote that when pushed will scroll through ccd-1, ccd-2,... off.
Your pda has a built in battery.The inbuilt one has lost its charge. To keep it from reseting to its original factory settings. You need to keep the main battery(the one you charge up) regularly charged.
It solved by fixing 1024X786 pixel solution.if it not possible by fixing it..
Then look over the VGA driver is correctly support or not
if not then you have to update the VGA (Display) by drivers
