anti theft light should blink every few seconds.
try disconnecting the battery for 15 minutes.
Anti-Theft-Perimeter
The perimeter anti-theft system consists of the following components:
- anti-theft indicator (THEFT)
- remote anti-theft personality (RAP) module
- hood switch
- keyless entry remote transmitter
- deck lid ajar switch
NOTE: The remote entry features will not function when the ignition switch is in the RUN or ACC position.
Up to four keyless entry remote transmitters (15K601) can be programmed at one time.
The keyless entry remote transmitters :
- Are programmable.
- Must be set at the same time.
- House four buttons.
- House three buttons (Mexico Anti-Theft System only).
Programming
Refer to
Section 501-14B.
Inputs and Outputs
The remote anti-theft personality (RAP) module receives input from the following components for anti-theft operation:
- Hood switch.
- Deck lid ajar switch.
- Keyless entry remote transmitter.
- Power door lock switches (LH and RH).
- Door courtesy input.
The RAP module distributes output to the following for the anti-theft system:
- Power door unlock relay.
- Power door lock relay.
- Liftgate unlock relay (Wagon)
- Park lamps relay.
- HORN relay.
- Dome lamp.
- THEFT indicator.
- Deck lid release.
Arming
The anti-theft system can be armed if:
- The ignition switch is in the OFF position.
- The panic alarm is off.
- All doors are closed.
NOTE: If a door is open, the anti-theft system is prearmed and waiting for all the doors to be closed. The THEFT indicator will remain illuminated for up to 30 minutes waiting for all the doors to be closed. If a door remains open after 30 minutes, the THEFT indicator will turn off and the system will return to a disarmed state. After all doors are closed and the 30 second prearm (continuous THEFT indicator illumination) is complete, the system is armed.
NOTE: If the theft LED does not flash after 30 seconds, check the LED FLASH PID to see if the feature is enabled.
The anti-theft system will be armed when the lock button on the keyless entry remote transmitter is pressed, all doors are closed and 30 seconds have elapsed.
When the system is armed, the THEFT indicator will flash quickly until the system is triggered or disarmed.
Disarming
NOTE: Using a key in a door lock cylinder to unlock is not a valid method of disarming the anti-theft system.
Untriggered System
NOTE: If the driver arms the system and remains in the vehicle, an untriggered system can be disarmed by turning the ignition switch to the ON position.
An untriggered alarm system can be disarmed by pressing the unlock button on the keyless entry remote transmitter.
Triggered System
NOTE: If the hood or trunk are open when the system is armed, it must be closed and opened again before it can trigger an alarm.
An armed anti-theft system can be triggered by the following conditions:
The deck lid door, liftgate, hood or any door is opened using a key, inside door handle, hood release, etc.
- The keyless entry remote transmitter can activate a panic alarm which is similar to the anti-theft alarm, but does not cause the THEFT indicator to flash.
A triggered alarm system can be disarmed by:
- Pressing the unlock or panic button on the keyless entry remote transmitter.
- Turning the ignition switch to the ON position.
Alarm State When Battery Power Is Cycled
When the RAP module is supplied power the first time at the vehicle assembly plant, the system will be in the disarmed state. The RAP module will remember whether it is armed, disarmed or triggered in its non-volatile memory. When the battery positive cable is removed and then reconnected, the system will return to the state it was in just before the battery was disconnected. If the system is in any prearm state, then the system will return to a disarmed state when the battery is disconnected and then reconnected.
Hi uneedpavanku, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
learn to post photos of any error on screens
or answsers will be wrong.
my guess is you PC is being hacked.
(infected) but I cant see your screen to be savvy can I.
did you buy this PC used?
you posted a monitor only and is not a PC. no PC stated.
but PCs have security modes, vast.
each has its own screens and warnings
is this a browser error or only on one web site?
Acer PC, what model (laptop or desktop ?)
some PC desktops have covers alarms,
that if lose lock the PC, or do errors.
but no PC stated.
this post is few months old is it resolved?
OP post a snap shot photo of what you see.
we can't see, see?
all cell phones have cam, use it"?
