HP Pavilion d4100y (PX181AV) PC Desktop Logo
Posted on Jan 15, 2011
Can't find the wireless switch - HP Pavilion d4100y (PX181AV) PC Desktop
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jan 15, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
587
Points
10
Do you have wireless on your desktop? Also, it might be a PCI card (meaning no real switch) if you have wireless on your PC.
If this is not the solution you are looking, write back.
The blutooth stack is download and install but "i activate the keys the key is fn + f11 then where is a radio on off switch pls tell me where is radio on off switch ? pls".
nitin m patil,
Wireless Switch
Wireless Technology
  1. The Vostro 1510 system ships with a wireless feature called the wireless switch. It is located on the left side of the system next to the ExpressCard slot. This switch serves to dectivate or activate the wireless antenna.
Wireless Switch LED Settings
The LED (located on the Hinge Cover) on the wireless switch works only when the system is powered on. A user can activate the switch and have it scan for networks only after going through a complete boot process. The switch is used to detect only wireless signals. This setting is in the BIOS under the Wireless section.
The LED indicates the following functionality:
  • Solid Blue - The system has detected a wireless signal.
  • Off - The system failed to detect a wireless device installed.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
I don't know how to turn on the wireless capability on myself?
What type of computer Desktop or Laptop & Make ???...
If your computer will not connect to a wireless Internet signal, one of the first things to check is whether your computer's wireless switch is turned on.
Many laptop computers have a switch located on the exterior of the computer that controls its ability to connect to wireless networks.
This switch can be accidentally turned off, preventing users from connecting to the Internet.
Determine if your computer's wireless connectivity has been disabled by viewing the network icon in the lower toolbar on your computer's desktop.
When there is a disruption in your computer's Internet connection, the icon will have a red X through it. For further information, go to the computer's Network and Sharing Center where you can troubleshoot connectivity issues and view available wireless networks.
If the computer isn't recognizing any wireless connections (and you're sure that there are wireless signals in your area), the likely problem is that the wireless switch is turned off.
Locate the wireless switch on your computer.
It may be located on either side of the laptop or along the back or front.
If you aren't sure whether your computer has a wireless switch, check the user guide that came with the unit.
Determine whether the switch is currently in the "On" or "Off" position.
The switch will be clearly labeled.
Push the switch in the direction of the "On" position to ensure that it is turned on.
If the switch was already turned on, see if there is a keyboard combination that will activate your laptop's wireless capability.
The key combination for your laptop will depend on your computer's manufacturer, but will generally involve a combination of the Function, Control or Alt and the F1 to F12 keys.
Check your user manual for your computer's key combination.
Troubleshoot problems finding wireless networks
http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-problems-finding-wireless-networks
How do I turn on my wireless connection
I do not know my wireless pc
b> If your computer will not connect to a wireless Internet signal, one of the first things to check is whether your computer's wireless switch is turned on. Many laptop computers have a switch located on the exterior of the computer that controls its ability to connect to wireless networks. This switch can be accidentally turned off, preventing users from connecting to the Internet.
Determine if your computer's wireless connectivity has been disabled by viewing the network icon in the lower toolbar on your computer's desktop. When there is a disruption in your computer's Internet connection, the icon will have a red X through it. For further information, go to the computer's Network and Sharing Center where you can troubleshoot connectivity issues and view available wireless networks. If the computer isn't recognizing any wireless connections (and you're sure that there are wireless signals in your area), the likely problem is that the wireless switch is turned off. Locate the wireless switch on your computer. It may be located on either side of the laptop or along the back or front. If you aren't sure whether your computer has a wireless switch, check the user guide that came with the unit. Determine whether the switch is currently in the "On" or "Off" position. The switch will be clearly labeled. Push the switch in the direction of the "On" position to ensure that it is turned on. If the switch was already turned on, see if there is a keyboard combination that will activate your laptop's wireless capability. The key combination for your laptop will depend on your computer's manufacturer, but will generally involve a combination of the Function, Control or Alt and the F1 to F12 keys. Check your user manual for your computer's key combination. Troubleshoot problems finding wireless networks
2helpful
How can I switch my wireless LAN on?
Maybe you don't have your wireless turned on. Look onboth sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can togglethe wireless on or off. Normally you would Press and Hold the FN functionkey located at the lower left of the keyboard, then hit the correct F1 thru F12key that toggles the wireless. The correct F1 thru F12 key to hit willhave the wireless signal icon )))) on it. Or it might have the icon of a towerwith the wireless signal icon )))). Normally the screen will displayWireless On or Wireless Off when you toggle the wireless.
I have sony vaio S. but the wirelees is not working no wireless host shown. how can i fix it?
Selecting the wireless function Follow the steps below to select the wireless function to be activated when you set the WIRELESS switch on your computer to on. Double-click (wireless switch icon) on the Notification area at the bottom right of the desktop.The Wireless Device Switch dialog box appears. Hints The appearance of the wireless switch icon changes depending on the selected wireless function. Point to the wireless switch icon to display the selected wireless function. Alternatively, you can right-click the wireless switch icon and select "show Wireless Device Switch settings" to display the Wireless Device Switch dialog box. Select the desired wireless function from "Wireless LAN" or "Bluetooth Device". Notes 5 GHz Wireless LAN is available on certain models only. You must select at least one wireless function to perform wireless communications. The 2.4 GHz and 5 GHz Wireless LAN functions employ different frequency bandwidths, thus are not compatible with each other. Checking the check box for both "Enable 2.4 GHz Wireless LAN" and "Enable Bluetooth Device" may cause poor communication performance or a connection loss due to electromagnetic interference. Click OK. The message "Setting up the wireless devices. Process may take several minutes. Please wait." appears first, then the Wireless Device Switch dialog box is closed, and finally the dialog box that describes what to do with the icon on the Notification area appears. Note While the message "Setting up the Wireless Devices. Process may take several minutes. Please wait." is displayed, do not: place your computer into power saving mode. turn off Windows or log off from the current user. turn on and off the WIRELESS switch. Confirm the settings and click OK. The dialog box about the icon on the Notification area closes. Hint If you check the "Don't show this dialog in the future" check box, the dialog box will not appear next time you close the Wireless Device Switch dialog. To analyze the network condition You can analyze the network condition if you select either or both of the wireless functions under "Wireless LAN" in step 2 above. Click the "Diagnose" button to start Windows Network Diagnostics. When the network analysis is complete, the result is displayed. If any problems are found, follow the on-screen instructions. Hint Windows Network Diagnostics is the function to identify problems the network has and present solutions to them.
IBM Thinkpad laptop Wireless connection not working laptop is asking to switch on wireless switch- "Where is it?"
Verify that the radio is enabled.
It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
Note: Follow the instructions provided to enable wireless card.
  • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
  • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
2helpful
Cannot the wireless internet setup
Hi kschmerer,
I understand that you are not able to setup the Wireless Network Connection in your Computer.
To fix this issue, please make sure that the Physical Wireless Switch on the Computer is turned ON and then try connecting the Computer to the Wirelss Network.
You can locate the Physical Wireless Switch on the front side of the Computer. Please move the switch toward right side to turn it ON.
Once the Physical Wireless Switch is turned ON, please try setting up the Wireless Network Connection.
If you are not able to to connect to Wireless Network Connection after switching on the Physical Wireless LAN Switch, try using the Wireless Switch Setting Utility.
To enable the Wireless Network Connection using the Wireless Device Switch Utility, please double-click the Wireless Device Switch icon on the right corner of the Taskbar. Then in the open Wireless Device Switch window, please click to check the box next to Enable 2.4Ghz Wireless LAN.
This should fix the issue.
Please post back if you have any questions or require further assistance.
Thanks for using FixYa.
1helpful
I am trying to connect my sons laptop to the wireless internet that I have .I have refreshed the wireless network connection and it says make sure the wireless switch on your computer is on. where is the...
What is the model of yuor laptop?
There will be wireless switch at the base of the laptop - turn it on. If still nok- - check system tray on the right hand side - you will find wireless switch utility there - enable wireless
Thanx
2helpful
Wireless not working
I assume it's a laptop/notebook.
If so then there is a switch near the light that is on when the adapter is on. It will be a very small slide switch, on the front or side edge. Simply find it and slide to on. Or if it's already on then try pressing the fn key and f8 together, as this sometimes is a second wireless switch.
I hope this helps
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
