HP Pavilion a705w PC Desktop Logo
Posted on Jan 15, 2011
I need disc 1 system recovery...i have all the others....disc 1 is cracked....is there a download for this recovery disc?
Anonymous
Level 1:
Scholar:
New Friend:
  • Contributor 64 Answers
  • Posted on Sep 27, 2011
Anonymous
Contributor
Level 1:
Scholar:
New Friend:
Answers
64
Questions
0
Helped
7578
Points
70
Only way to get one is to call HP directly. You can reach them at this number, 1-800-474-6836. However, I believe your PC is already out of warranty. It will cost you for the support and for the recovery disc.
I suggest you getting a separate Operating system. (Windows XP). then you can just download and install the drivers for this computer by going to this link :
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=435558
Hope that works for you.
Trying to restore back to factory settings
System Recovery
When you've tried other methods of repairing your
system software (like System Restore or Application
Recovery), you may want to use the Compaq System
Recovery program as a last resort to reinstall the software.
When necessary, you can reinstall the operating system and
the application software that was originally installed on the
PC at the factory by using the System Recovery program.
WARNING: The Compaq System Recovery
program will delete any data or programs
that you installed after purchase. Be sure to
back up any data that you want to keep onto
a removable disc.
The System Recovery program uses a special recovery
partition on the hard disk drive that stores an image of the
original software.
NOTE: The System Recovery image is in a partition area
of the hard disk drive and takes up part of the total drive
space. This disk space is not usually available for your use.
In the unlikely event that you replace the hard disk drive,
or somehow damage the data in the special recovery
partition on the hard disk drive, use recovery discs to
reinstall the operating system and software on the hard disk
drive. See "System Recovery Using Recovery Discs."
Make your own recovery discs (CDs or DVDs) before you
need them; see "Creating Recovery CDs/DVDs." You can
also make the Recovery Tools CD. This CD contains utilities
that allow you to make changes to your hard disk drive; see
"Using the Recovery Tools CD."
Starting System Recovery
if the PC Is Responding
1 Turn off the PC. Disconnect all peripheral devices from
the PC except the monitor, the keyboard, and the mouse.
Turn on the PC.
2 Click Start on the taskbar, choose All Programs,
choose PC Help & Tools, and then click Compaq
System Recovery.
3 Wait until the System Recovery window appears asking
Do you really want to start System Recovery?
4 Click Yes to continue with the recovery process. If you
created recovery discs, you may be directed to insert
recovery disc #1. If the Recovery disc is a DVD, be sure
to put the disc in a DVD drive.
5 The PC starts the recovery; wait for the onscreen
instructions to display, and then follow those instructions.
6 Complete the PC startup, finish the registration process,
and wait until you see the desktop. Then, turn off the PC,
reconnect all peripheral devices, and then turn on the PC.
Starting System Recovery if the PC
Is Not Responding
1 Turn off the PC. If necessary, press and hold the On
button until the PC turns off.
2 Disconnect all peripheral devices from the PC except the
3 Press the On button to turn on the PC.
4 During the startup, do the following to enter the System
Recovery program:
When the black screen with the Compaq logo appears,
press the F10 key on the keyboard. (You have only a few
seconds to press the F10 key before the normal startup
process continues.)
reconnect all peripheral devices, and turn on the PC.
2answers
Where can I get/download free restore dics for my Toshiba Satellite a-135?
Theres restoration discs and then theres the original operating system discs,restoration discs only work under certain conditions far better to formatt and re-install operating system
Administrative password forgotten
You have to either reinstall the operating system but for that you need the recovery discs. second option is you can try to login to the administrator account in safe mode and reset the pasword from there.
If you are not able to arrange the disc or login to the safe mode you would have to download a third party software to crack the password
System recovery disc
you will want to look on the computer for a serial sticker that should have a windows or other operating system cd-key you can use that to download or have a disc mailed to you
hope this helps
Robb
I need to format drive and perform Full system recovery using Gateway system recovery with windows xp recovery cd is there a download or ??????
1) You can download and make a bootable disc whit some usefull tools: http://www.ultimatebootcd.com/
Partition Tools can help you (format partition).
2) Insert your recovery CD on your PC and follow the instruction to recovery system.
FULL VERSION OF XP PRO TO DOWNLOAD ?
At the moment, the only method of getting Windows XP install media is by purchasing the disc or ordering install media directly from Microsoft. The other way is if you're a MSDN subscriber, you can usually download software images from Microsoft and use your own key.
The other way to do this is by finding a friend who has a Windows XP cd of your version [for example, Windows XP Home OEM, OEM meaning that the disc came with a manufacturer such as Dell or HP, or Windows XP Home Retail, meaning that the disc came in a Windows XP Home box someone purchased]. If you can borrow thier disc, you can use your key off of your COA [Certificate of Authenticity] which is a sticker on your computer showing your 25 digit license key. This will install Windows XP legally on your system again.
If you own an OEM computer like Compaq, HP, Dell, etc, you can also try contacting support for that PC manufacturer and seeing if you can order recovery media for your computer model. This will install the operating system, all drivers, and software that originally came with your computer back to default when you bought your PC. You may also have recovery software installed on your computer. Look under your start menu and see if you have a suite of software from your PC manufacturer, including recovery software or system restore software.
Best of luck!
Sytem recovery disc 1
1) Try to make a copy doing an "IMAGE DISK"
2) If you couldn't:
You can download all your drivers for your desktop computer
without a Restore Disk. (But You will need a copy of OS)
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCVRX753&LOC=3
HP MEDIA CENTER 864N Desktop PC&p RECOVERY CD
NOTE: Most HP and Compaq desktop PCs that ship with Windows Vista and XP do not come with recovery discs. Instead, they use a hidden space (partition) on the hard drive to store the recovery information. Using a hidden partition provides a convenient, more stable recovery solution.
Step 1: Create a set of recovery discs or a recovery DVD
To create the recovery disc set, Click Start , All Programs , PC Help & Tools (or similar), open the HP or Compaq Recovery CD-DVD Creation software, and follow the on-screen directions.
If you cannot create recovery discs or your discs have become damaged, continue to the next step.
Step 2: Order recovery CDs on the Web
If you are not able to create a set of recovery discs, you may be able to order a set of replacement discs from HP. HP maintains a stock of replacement recovery discs for several years after the product has been released. However, because of licensing restrictions, HP is only able to provide these recovery discs for a limited time. If your computer is several years past its warranty period, HP may not be able to supply replacement discs for your computer. If this is the case, you can install a new operating system that meets the minimum system requirements of your computer, or, alternatively, upgrade your computer hardware.
To find out if HP has recovery discs that you can order and to order them from HP, use the following steps:
NOTE: The steps in this section apply to United States and Canada. For Europe, Middle East, and Africa please refer to the HP support document Europe, Middle East, and Africa - Statement on the Availability of the Recovery Software on CD . For other countries/regions, contact your local HP support center for information about obtaining recovery CDs.
Go to the Software & Driver Downloads page .
Enter the product number or model name for your computer into the field provided.
Figure 1: Product name/number field
Click the operating system link (the version of Windows that came with your computer).
Figure 2: Example of operating system link
Find the Recovery Disc ordering section and click the link to start the ordering process.
NOTE: Before trying to order, make sure that you have read the important "Read this..." information listed in this Recover Disc ordering section.
Note: - If the link to order a recovery disc set is not available, there may not be any more sets available for purchase. HP cannot create recovery discs that contain a version of Windows that has been obsoleted by Microsoft, such as Windows 95, 98, and Me. Some recovery disc sets may have run out of stock and may not be available to order.
Figure 3: Recovery disc ordering links
Follow the directions from the "Read this...” article and from the ordering pages to complete the ordering process.
NOTE: The ordering pages use a secure connection to protect your privacy.
If you cannot create a recovery disc set and you cannot order a recovery disc set from HP, go to the next step.
Step 3: Contact Support
If you have tried the steps 1 and 2 and could not create or obtain a recovery disc set, contact HP Customer Care . HP Customer Care may be able to send out new discs or replace defective versions depending on your situation and availability.
2answers
Computer virus ruined my tower, hp pavillion s7320n, prod. #:EP140AA. I need a recovery disk? Drivers disk? And a lot of technical help. Marco
If you are not able to create a set of recovery discs, you may be able to order a set of replacement discs from HP. HP maintains a stock of replacement recovery discs for several years after the product has been released. However, because of licensing restrictions, HP is only able to provide these recovery discs for a limited time. If your computer is several years past its warranty period, HP may not be able to supply replacement discs for your computer. If this is the case, you can install a new operating system that meets the minimum system requirements of your computer, or, alternatively, upgrade your computer hardware. To find out if HP has recovery discs that you can order and to order them from HP, use the following steps:
NOTE: The steps in this section apply to United States and Canada . For Europe, Middle East, and Africa please refer to the HP support document Europe, Middle East, and Africa - Statement on the Availability of the Recovery Software on CD . For other countries/regions, contact your local HP support center for information about obtaining recovery CDs.
  1. Go to the Software & Driver Downloads page .
  2. Enter the product number or model name for your computer into the field provided. Figure 1: Product name/number field c00772934.gif
  3. Click the operating system link (the version of Windows that came with your computer). Figure 2: Example of operating system link c00772003.gif
  4. Find the Recovery Disc ordering section and click the link to start the ordering process.
    NOTE: If the link to order a recovery disc set is not available , there may not be any more sets available for purchase. HP cannot create recovery discs that contain a version of Windows that has been obsoleted by Microsoft, such as Windows 95, 98, and Me. Some recovery disc sets may have run out of stock and may not be available to order. Figure 3: Recovery disc ordering links c00772004.gif
  5. Follow the directions from the "Read this.." article and from the ordering pages to complete the ordering process.
    Thanks. Please take a moment to rate this as FixYa.
    Thank you.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
