SOURCE: HP Deskjet 9300 cannot print A3 size documents
Goto Start-Settings-Printers & Faxes / Right click printer and goto "printing preferences" NOT PROPERTIES.
Click on Basics tag then advanced / Uncheck " If paper is too small, eject page and pause" / OK / apply /OK
Simon
SOURCE: Mac not printing to HP Deskjet F2200 series
1) First let's make sure the hardware is working. Place a document face down on the scanner glass. Press Start Copy Black. Did it scan and print?
If not, please let us know.
If it did, go to the next step.
2) Please confirm the USB cable is plugged firmly into the back of the printer and to the computer. Do not go through a hub, switch, or router.
3) Click on your Apple icon (upper left corner), System Preferences, Print and fax.
Do you have the F2210 printer listed more than once?
I am going to suggest removing the F series printer. Highlight it and press the minus button to delete. Once you have removed it, close all windows back to the desktop.
On the computer click on Hard Drive > Applications > Hewlett-Packard > Device Utilities > HP Setup Assistant. Follow the on screen directions to add the printer back to computer. Do not re-register the printer (choose skip or register later). Once your are able to click finish, try printing again.
I would suggest trying to print from Text Edit first. This will rule out any possible issues with the Word document you were trying to print. Click on Hard Drive > Applications > Text Edit. Type your name in the untitled screen. Click on File > Print. Make sure the F2200 series printer is selected. Click Print. Did it print?
SOURCE: hp deskjet f2280 all-in-one printer
In this case I would suggest you to Add a printer with deskjet 990c printer driver. It might resolve the issue.
Manually install the printer driver
SOURCE: the document cannot be printed due to a system
To resolve the issue, follow the steps below.
1. Right-click on My Computer, and select Properties.
2. Click on the Advanced tab.
3. Under Performance, click Settings.
4. Click the Data Execution Prevention tab.
5. Select the Turn on DEP for all programs and services except those I select: option.
6. Click Add....
7. Browse to C:\WINDOWS\system32\spool\drivers\w32x86\3\hpzeng07.exe and click Open.
8. Click Apply.
9. Click OK, and OK again.
Testimonial: "I've worked on this for 4 days. Thank you very much. This was the quickest easyest soulation I've ever had with any problem."
SOURCE: my hp f 380 printer wont print pdf documents
in this case
open pdf
the click on print
now you need to look for the option that says print as image and this option has to be checked
you can get the option by clickon on advanced or prefrences
Thanks
or make sure you not giving print in grayscale mode.
Hope this helps. Please rate my response.
Thanks.
Have a good day
