Kodak ZD710 Digital Camera Logo
A
Anonymous Posted on Jan 14, 2011
While taking pictures this weekend my wife got a memory card needs formtting message. If you format the memory card you lose all the pics. Not sure what to do...
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Jan 14, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2197890
Points
38521
This sometimes appears if you forget to use the "safely remove hardware" function when you disconnect the camera or card from the computer. Use a separate card reader to download the pictures and then format the card in the camera.
My memory card is asking to be formatted. I've only had my camera about a month and decided yesterday to download my pictures. I took the card out and then put it back in the camera because I wasn't able...
Take the card to a Walmart and insert it into one of their picture kiosks. You can print your pics or make a CD of them. Then, format your card in your camera.
Feb 21, 2011 • Cameras
While taking pics, a message box came up saying that my card needs to be formated. I am not sure what prompted this. I am afraid I will delete the pictures on it.
SaveMyUsb.com can recover data from most damaged faulty and corrupt flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
My girl took pics of wedding Saturday and viewed pics earlier today. When she went to look at them again, a message " Disc in Drive E is not formatted. Do you want to format disc now?" Of...
do not format -- you will lose the pictures
instead go to another computer that supports SD memory and CDRW. insert into that computer and then take all the PICS, save into that computer. now take a blank CD and take the saved PICs and burn into CD.
Also, to ensure you dont lose these pictures (PICs) you may want to buy a 4G or 8G USB thumb drive (about $10-$15 or less) -- drag and drop all the PICs (saved on that computer) into the USB thumb drive. Now you have on CD and USB drive.
hope this helps
2answers
I were on holidays last weekend and after taking about 600 pics,when i want to review my photo,the screen started telling me there was an 'error with memory stick'. Now it's telling me 'error formating...
wow, that's the first time that I heard of a Memory Stick Pro 4gb failing for someone. Try to take the memory stick pro to Walmart photo center to see if they can read the pictures. If they can't (or your local drug store) I don't know who can.
Good luck on this.
Losing photos
They are probably still there. Get yourself a card reader and use it to download your pics. f1eb652.jpg
Getting error message "Memory card requires formatting"
I found software to help! Go to www.cardrecovery.com for a free trial to recover all your deleted, formatted or corrupted files.
Digital camara and memory card
Basically picture files in memory card have corrupt data that's why computer doesn't recognize it.
HP recommends following action...
Close the HP Image Zone or HP Photosmart Software, disconnect the camera from the computer, and reset the camera. (can see this at HP Support)
2nd option is to find some memory card data recovery software on internet and use it to correct data files in memory card.
Thank you.
Oct 03, 2008 • HP Cameras
New memory card.
See if there is a copy feature in menus where you can internally copy from internal memory to card-kodaks and some other manufs offer this feature-i would offload internal pics w/usb to computer and then just start using new card-get a memory card reader also and you can put from comp back to memory card w/reader-no need normally to format new memory card-just don't format internal or you will lose pics
Memory card problem
The only solution left is to get a card reader and insert the card in the card reader.
when the card is detected it will show a removeable drive in My Computer. Right click on the removeable drive and click on properties....now click on the the tab which says Tools......now under error checking click on Check Now......now click both the option that is Automatically fix the system errors and Scan for and attempt recovery of bad sectors.
After the scan is complete the card will work fine.
Memory card formatting
Unfortunately, there is no way to format your card without losing any saved pictures. Sometimes, if you insert your card into other cameras or printing kiosks at walgreens or target, it will work. it's a long shot though. Chances are, you may have to lose your saved pictures :(
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
