SOURCE: Sansa E250 Cannot Reformat, Blue Ring Only
Not sure what e200 tool you are referring to.
But this is the one provided by SanDisk;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
SOURCE: sansa 250R
u have no idea how many people say this but what I would do is reset it by sliding the hold butten on top so the orange is showing. then hold down the record button on the left side
Good Luck
SOURCE: SansaE250 Startup and intial setup problems
which format of video songs can this device accept?
SOURCE: sansa e250 keeps saying "SYNCHRONIZE TO CONTINUE YOUR MUSIC SUBSCRIPTION"
Here's the deal with WMA files - once your subscription expires (or really, the license on the WMA file expires) - you will have to renew your music service subscription or the song will no longer play on your device.
Use Mp3 format songs - they'll never give you this problem.
SOURCE: Reformatted sansa e250 need help
When you format it, it deletes everything on the player. You'll just have to put everything back on it.
