If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
SOURCE: defrost timer location
need to know the make and model...
GE are in the top right back
Frigidaire are under the toe plate left and right also in the back by the compressor. cheaper frigdaire are in the middle center top refer... so you see they hide them in a lot of places..
SOURCE: Need to Replace Defrost Timer
check bottom back left should be a small hole with a small plastic place to turn with a srew driver some are insidethe fride on the left side arond where the lite is if you see a mall plate with a srew open it it should be there thanks from gilles
SOURCE: Location of Defrost Timer
you unit do not carry it carry a board it at the back off the unit
SOURCE: maytag fridge defrost timer location
its not a timer , but an adaptive defrost control board, in the upper rigth hand side of refrig compartment, atop the control housing heres the part number 61005988.
check this site ==> http://www.fixya.com/support/t1330051-defrost_timer
Good luck,
Tony Ip
