SOURCE: Seiko Chronograph Sport 150 - Problem: After
Please folow this link:
http://www.seiko.co.uk/support/instructionbooklets
Enter your calibre code (its on the back of your watch, it will explain which numbers to you on the website), you'll then be able to download an instruction manual for your watch, this will detail how to adjust hands to their corect starting position :)
Testimonial: "PDF link states reseting the watch is the problem, and now that I have instructions, I should be able to reset the watch. Thanks"
SOURCE: My SLL 015 has been unused for 3 or 4 years.I have
I checked on the web site but couldn't find your model but I did find the instructions site, which may be able to confirm if the operation you describe is normal.
To download the information, it is necessary to enter numbers fri=om the back of your watch so I suggest you follow this path:-
Go to "www.seikowatches.com", select "products" from the top of your screen.
Go to the bottom of the screen and select from the menu on the left "instructions on how to use your watch" and follow the instructions.
I hope that you find the answer you need.
SOURCE: I have a seiko chronograph sports 150 watch; had
As jimmyguru said.
1. Pull the crown to the second position (all the way out)
2. Push and hold the reset button and allow the chronograph hand to rotate near the 12 o'clock position.
3. Release the reset button.
4. Repeatedly push and release the reset button to find tune the hand position until it is right at 12 o'clock.
5. Push the crown back in.
SOURCE: men's seiko perpetual calendar watch stopped
mcdevito75 here, Your Jeweler had to mention your watch would go to Seiko for repairs. Seiko should notify you or your Jeweler with the repair particulars.
SOURCE: I need manual instruction for Pulsar Tech Gear
You can get instructions from their web site "Seiko.com".
Click on "support" and then on " instruction booklets" and then scroll down the
page and you will see
a list of watches.
Download the PDF for your watch.
