There should be a cover behind the laptop, unscrew these tiny screws and the back cover should open. Then you want to located where the rams are at. In some case the ram slot is already being used by the original rams and you need to take these out to install the new ram. Before hand, make sure your laptop support the correct type of the ram, in your case it will support ddr2 sdram up to 4gb. So pretty much once you locate the ram slot after opening the back panel... then just install it.
