Question about D-Link DIR-625 (790069292637) Wireless Router
Hello sir, i have a router D-Link TM-G5240. I have a problem encountering right now and it suddenly my computer cannot connect to internet as well as my other laptop using the wifi connection. So, i re-install the D-Link and i have completed all the instruction given with the d-link installer. It was 100% successfully installed and saying good connectivity, then after installing, i connect it again to internet, same thing happed, no internet, but it says here that i have internet connections. what would be the problem and do you have any solution for these? i also tried to reset the router and installed it again. but no luck. ill wait for your reply sir, thank you, have a good day..
6ya staff
SOURCE:
Anonymous
  • 145 Answers
SOURCE: D-Link DI-524 4 Port connection Problem.
Perhaps the router is not broadcasting its SSID, therefore is invisible to would be tappers. Type 192.168.0.1 into a browser on a computer directly wired to the router, leave the username blank, if you havent changed it, the password is admin by default. Once logged in check that wireless is enabled and that you are broadcasting the ssid, you may want to setup/change security settings for the wireless connection at this time also.
Posted on Feb 11, 2008
sandeep239
Sandeep Shrivastava
  • 59 Answers
SOURCE: Internet connection lost when wireless printer added to network
for reseting the password of ur dlink router u have to press the rest button on the dlink router (genrallyit on the bottom or on the back of the router it is like a hole u have to use a pen or pin to reset the router back to its factory default settings after that password of the router will automatically back to admin or password login to ur router change the settings to static ip in the router so that u can provide the static ip of the other router to ur this router (example if primary router HL 2170 ip address is 192.168.1.1 then u will provide this dlink router the ip address as 192.168.1.5, subnet 255.255.255.0 default gateway 192.168.1.1 primary dns 192.168.1.1 now save the settings in the dlink router now the ethernet cable from ur other router will go directly in to the internetor wan port of this router. now connect wirelessly to any router both will work fine without any problem
Posted on Jun 03, 2008
kakee
Michael Galve
  • 1269 Answers
SOURCE: configuring D-Link DI-524 router with airtel beetel 110bx1
Make sure you can go online directly to the airtel broadband. If internet works fine, connect the D-Link router to the Beetle. That should be going to the Internet port or WAN port of the D-link. Then your PC to port 1. Try to power cycle both devices now. Unplug the power to the router first then to the modem. Wait for 30 seconds. Power on modem first, wait for the lights to go solid, then power on the router. Check if the internet works fine hardwired. If it is, wireless should work as well. Just connect to the signal coming from the D-link.
Posted on Nov 01, 2008
Anonymous
  • 132 Answers
SOURCE: Cannot install D-Link router
You may try typing admin on the username field. Just leave the password field empty.
Once you're in the setup page, click on WIRELESS tab which on the left side of the page. On the Wireless page, you will see the wireless settings set in the router. You may also enable the wireless security on that page if there is not security enabled yet.
Please check this for your reference http://support.dlink.com/Emulators/di524/h_wireless.html
Hope this helps!
Posted on Nov 13, 2008
firesnake09
Melvin Ramos
  • 2923 Answers
SOURCE: cant find my wpa # needed to reconnect my router
For routers, there no way to see what the WPA key is. Once you check the Web UI of the router and check the security, all you will see are asterisks (*********). Because WPA is a security and needs to be hidden. As the owner of the router, you should always remember what your WPA key is.
In order to resolve this issue, you need to reset the router back to factory default, set up a new WPA key and save it.
Or you may contact the manufacturer of the router and see if they have a record for your router
Have a great day!
Posted on Oct 29, 2009
TM-G5240 router is slow
Is it the wireless device or your ISP? Location the same on wireless device? Computer same place? Channel the same? Antenna the same? Cables the same? You will never get what is advertised. That would under perfect conditions and the Max it will work. Figure the miles of cables and equipment between you and the ISP and all the places it could degrade a signal. Try a High location for the device, change channels.
Jan 02, 2013 | D-Link Tmobile Hotspot Tmg5240 Wireless...
My laptop doesn't have a CD reader. I bought the D-Link T-Mobile TM-G5240. Where do I install it?
Hi you`ll need to put the cd on a pc with a cd rom the copy it to a flash drive a an external harddrive then put it in the laptop and install it
Dec 16, 2011 | Cell Phones
How can i block my router TM-G5240 to other computers?? tks
one word "permissions"
you have to tell the router and the firewall that you don't want "abc" user to use the router.
this is done by logging into the router and allow/disallowing the user by MAC address ( Media Access Control) .
depending on the router to access it is going to a browser window and entering either 192.168.0.1 or
192.168.1.1
instruction set to secure your router is in the "helps" file.for
1.select the "Advance tab
2. select filter "MAC'
3. Enter name
4. under MAC address enter MAC address
5.on the DHCP Client select DHCP client from the pull down list; click Clone to copy that MAC address
Jul 23, 2011 | D-Link Tmobile Hotspot Tmg5240 Wireless...
Trying to run setup wizard on my WRT54G-TM,so i can block other people from borrowing my internet.I have one desk top hooked up and two laptops, works great ,but when i run the wizard disk it tells me...
To test your Internet connection, connect a LAN cable from your computer to the DSL or cable modem and if you can browser the Internet then your Internet connection is OK, then the problem is the LAN cnnection to the Linksys or the Linksys may not configured correctly.
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link'sconfiguration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 21, 2011 | Linksys WRT54G-TM Wireless Router
I bought a D-link TM-g5240 . The wizard setup doesnt work. error:Your ethernet connection could not be verified. It says disanle firewal. I did disable everything, antivirus and firewal. Same...
Are you trying to connect to this router wirelessly or with an ethernet cable? If you are already using an ethernet cable, try using a different cable in case the first cable is damaged.
May 05, 2011 | Computers & Internet
D link security
refer to page 12 and continue on through the user manual for the steps on how to login and secure the router. It is a very straightforward process. Here is the link to the manual:
http://docs.bgmicro.com/pdf/tm-g5240.pdf
Thank you,
Lee
Aug 25, 2010 | D-Link AirPlus DI-524 Wireless Router
I can't connect to the internet with dlink router
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 06, 2010 | D-Link DIR-625 (790069292637) Wireless...
Problem with D link wireless router
I recommend that in the first instance, you can upgrade the firmware for the router - you can go to this link to do this:
http://support.dlink.com/chooseCountry.asp
Mar 20, 2009 | Linksys Wireless-N WRT150N Router
Need to add Linksys WRT54G-TM wireless router with Linksys SPA 2102 phone adapter
your SPA2102-R seems to have one ethernet connection and one internet connection.
your WRT54G-TM seems to have one internet connection and 4 ethernet connections.
What you are trying to achive is; plug a ethernet cable into the ethernet connection on your SPA2102-R then plug the other end into the internet port of the WRT54G-TM
hope this helps, I have assumed that you intend to use a DSL broadband supplier not ADSL.
if you are changing service from DSL to ADSL then your WRT54G-TM needs to be first in line configured and working. then plug the internet port from the SPA2102-R into any of the WRT54G-TM ethernet ports.
Nov 06, 2008 | Linksys Wireless-G WRT54G Router
D-Link DIR-625 (790069292637) Wireless Router Logo
134 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
