phone memory should always be free... its the ram for your phone... you shoul keep all your files , applications and messages in memorycard ..... if memory in phone is low it will work slowly and you will not be able to open large sized applications in your phone
Hi, If your mobile has memory card delete unwanted files or delete files in gallery, unwanted messages, applications in your phone memory and free its space. my suggestion for you, don't always store to the end of you memory. then mobile will function slow and gets hanged.
Do you see the msg "Memory Full" and not able to make space free even after deleting songs/photoes etc. if yes then read next para.
This phone has a bug. which is due to the lifebolg application in the phone. This application comes by default with the phone and is of no use. The process which starts automatically when the phone is started, cause the problem and consume all the phone memory. It leads to "Memory Full" display in the screen. Does not matter how much data u delete, u will always see this.
As a result you will not be able to see your missed calls, ur msgs..etc..so if u have this prob, let me know I will tell u the solution.
hi, it could either be two problems..the 1st problem could be that you do not have enough memory on your phone i.e. the phone memory could be low. so all you need to do is to delete some applications you have downloaded on the phone so as to create more space for your phone...delete from phone memory and memory card..please note, if you have an application that is not compactable with your phone,delete it please because that could also be the problem. the second option could be that your phone is infected..so all you need do here is to scan for virus.
Hi, You can delete your old messages both (inbox and outbox messages) the also go to your call log menu, to delete all your old calling info. be it miss call, dial call or received call. This should be able to free the memory of the phone. Also try to remove or delete those applications that you think you don't always use or delete some of your newly installed application to free your phone memory.
and if you think all this have benefit for you, then get a higher bytes memory card for your phone.
nokia n72 has a slow operating system which gets even slower if the battery is low and thw problems are doubled if the memory is near full.
Sometimes unsupported applications hang on it which can only be stopped by removing the battery and restarting the phone.Restarting may take a lot of time but have patience and once the phone restarts delete the application which caused the hanging. An advice is to keep the memory card half empty.
format your phone - but you will loose everything Otherwise go to memory details - go to applications and select options, scroll down to memory details and select phone memory. check how much u have used and what is free. Then delete accordingly - all your music files etc etc and bingo - now stop the tears
