SOURCE: discolored white nautica watch band
If your watch band have UV sensitive pigmentation in it, there is nothing you can do, but buy the new band.
Find your nearest jeweller and ask to clean watch band in ultrasonic cleaner for 1 hour. If this kind of cleaning doesn't help, that means your watch band is UV sensitive and is and will be discolouring more and more by the time.
Alternatively you can try to clean it with the lighter fluid (ZIPPO). Soak a soft cloth in to lighter fluid and clean the band. Start with a small area inside band to make sure the fluid is not reacting as dissolver, as some resins react quite vigorously and tend to transform into chewing gum sort of state.
And again- if this cleaning doesn't help, the band is UV sensitive and discolouring is taking place.
That discolouring is happening becouse some of the colour pigments used in resin manufacture are sensitive to ultraviolet light and when exposed to sunlight or daylight, they react in a chemical
way, changing molecular structure, wich we see as the colour change.This process can not be reversed and this is why the band can not be cleaned.
Do not forget to rate please.
SOURCE: Need New Watch Band
i have repaired watches like this before. I advised u to go to www.the watchery.com and www.lucienpiccardusa.com or www.ebay.com. there u can buy and choose branded lucien piccard watch band.let me know if u see what u wanted...
SOURCE: Where can I buy a new White Resin Nautica watch band.
If you go to the web site www.nauticawatches.com and select "service center" you will be able to see all the service centers. Choose your nearest and ask them.
Testimonial: "THANK YOU"
SOURCE: How do you replace or clean the white leather part
mcdevito75 here, I don"t think there"s too much more you can try as I have had the same problem, Best Bet, replace the strap.
SOURCE: I have a calumet watch,
Polyurethane Band
Polyurethane Bands, which are made of soft plastic, may turn hard after 2-3 year's use. Colour fading can also be seen.
If bands are kept wet and in highly humid locations or are exposed to sunlight for a long time, the deterioration of the bands may be accelerated in a relatively short period and some cracks may appear on the band surface. (This is called 'hydrolytic cleavage of polyurethane')
Kindly pay attention to the condition of polyurethane bands, which are often worn in such occasions as marine sports/outdoor activities
CAUTION!
Do not use solvent/chemicals (benzene/thinner/breach) for band/bracelet cleaning!
