Anika Tech Support to give our clients the technical expertise IT Support including Desk Side Support, Remote Support, Project Management, Security, Business Growth and Customer service.
https://www.anikatechsupport.co.uk
https://www.anikatechsupport.co.uk/managed-it-support
https://www.anikatechsupport.co.uk/cloud-hosting-services
https://www.anikatechsupport.co.uk/projects-consultancy
https://www.anikatechsupport.co.uk/cyber-security-continuity
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
you could select the safe mode option and see if you can get the extended desktop again but first you will have to find out why it crashed
if you select last known good configuration that worked it might give you an idea
hope it helps
