Master
- Posted on Jan 13, 2011
Re: Prints fine but ink does not stick on the paper
First try cleaning the scanner glass with alcohol or spirit. If you notice problem is still there reset the printer as per below.
Please try below resets one after the other if issue is not solved by 1st method.
Power Drain:
- Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
- Press and hold the Power button for 60 seconds.
- Connect the cable and turn ON the printer.
Partial Reset
- Remove the power cable from back side of the printer while its ON.
- Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
- If printer turns OFF, press power button to turn it ON.
Semi-Full reset
- Remove the ink cartridges.
- Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
- Insert the ink cartridges.
NVM Reset
- Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards
Riztech
