Most likely your latch assembly on unit has failed.... try resetting breaker to unit and make sure latch is not half opened or half closed while breaker is off... after checking reset breaker and see if this helps if not then probley going to need a new latch assembly and or possibly the control on unit... self clean on all ranges and ovens are trouble in my opinion they get entirely to hot and usually are ran to long... i know you said yours didn't work leads me to believe there may have already been damage to one of the pcb relays on the control but try the above first and you may luck out.... good luck to you
Seems
like you found out the hard way what I wrote about in this
tip...
Check it out it also contains some thing to try on how
to unlock that oven..
Self
Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I
never would have used the self cleaning option. Thanks for the info!!
" - amymrocks
