Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
Posted on Jan 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Forgot password for router - Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Rakesh Warrier
Level 3:
  • Master 708 Answers
  • Posted on Feb 20, 2015
Rakesh Warrier
Master
Level 3:
Answers
708
Questions
0
Helped
209436
Points
1609
Hi, Do you have a computer that is connected to the wireless network ?
If yes, Heres how to get the password.
Find your password on a Windows PC
If you have a computer running Windows that is connected to your wireless network, you can find the password by doing the following:
Windows 8.1: Find your password Step 1: Swipe in from the right edge of the screen, and tap Settings.
(If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, and then click Settings.) Step 2: Tap or click the network icon (forgot password for router - d6916536-a5d6-48c3-9da5-a5e1b1911348.png?n=wireless-network-icon.png or ) for the network you want to connect to, and then tap or clickConnect. Step 3: Swipe in from the right edge of the screen, and tap or click Search. Step 4: In the search box, enter view network connections, and in the search results tap or click View network connections. Step 5: In the Network Connections window, press and hold or right-click the network name, and then tap or clickStatus. Step 6: Tap or click the Wireless Properties button. Step 7: Tap or click the Security tab, and tap or click the Show characters check box. Step 8: The password for the wireless network is displayed in the Network security key field. Windows 8: Find your password Step 1: From the Start screen, swipe in from the right edge of the screen, and then tap Settings.
(If you're using a mouse, point to the upper-right corner of the screen, move the mouse pointer down, and then click Settings.) Step 2: Tap or click the wireless network icon . Step 3: Tap and hold or right click on a wireless network name, and then choose View connection properties. Step 4: Select Show characters to see the wireless network password. Windows 7: Find your password
Step 1: Click the wireless network icon on the taskbar (lower-right corner). Step 2: Right-click your wireless network name, and then select Properties. Step 3: Select Show characters to see the wireless network password.
Hope this helps
Regards
Rakesh Warrier
facebook.com/quietmouse89
Paula Haley Tennison
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 09, 2015
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
194
Points
Which password do i use to connect my ROKU? My first sign on or yahoo? Windows? or Xbox? I am very confused? Please "HELP" Thanks so very much.
Donivan Wise
Level 2:
Sergeant:
  • Expert 254 Answers
  • Posted on Jan 13, 2011
Donivan  Wise
Expert
Level 2:
Sergeant:
Answers
254
Questions
0
Helped
65743
Points
574
Most Belkin routers have a temporary password that comes with the router if your router is one of them you will need to contact Belkin to have them give you a temporary password if thats the case here is the phone number for Belkin 800 222 014.
However you may be able to reset your router to make it unsecure, to do that there is a reset button located on the back of your router simply press and hold for 15 seconds or until router resets, you may need something like a paper clip to access the reset button. Good luck
Forgot pass word
Forgot my belkin router password - CCM
ccm.net > Forum > Internet
Jun 10, 2015 - I have been trying to set up intranet through a Belkin router and my tv keeps asking me for the password for my router. I don't remember it at all I ... Wifi router password reset [Solved] - CCM
Oct 20, 2015
Forgot my password for my router??? [Solved] - CCM.net
Nov 20, 2012
Forgot password to netgear router. - CCM.net
Jun 23, 2011
Belkin admin password [Solved] - CCM
Sep 10, 2010
More results from ccm.net
Belkin Router Password Lost!! - Forum Thread - PC Advisor
www.pcadvisor.co.uk > Forums > Tech Helproom
How do i get my password back when i press the forgot password button and then when you do your password i doesn't work what do you do?
A password for your router? Most routers don't have a "forgot password" button, so I think maybe you're in the wrong category.
If you forget your router password, the standard practice is to restore factory defaults on your router (usually by pressing the power button for 20 seconds or something like that; check the manual for your router). Then the password is reset to the factory default (usually blank or "admin" or "password"; check the manual for your router).
How to change passwords
If u forgot the password reset the modem/router....usually the reset button will be at the bottom or rear of ur modem/router and after reset ur default username password will be admin / admin or admin / password
2answers
D-Link wireless router forgot password how may I recover or assign a new one
A wireless router password wont be recovered unless you still have the password you can enter or if the router is unmanaged without an admin password.
another option would be resetting your router to be able to get through the router and assign a new password.
here's how: you need to directly connect your computer or laptop wired going to your router not using a wireless one. then reset, make a new network configuration and put your admin password later. dont forget to backup your router config. in a folder together with your password so the nextime you forgot any thing or change anything. just look back to your folder where you put your backup config. and password.
Unable to connect my tv to the router because i forgot the password
You forgot password to router or password for connection? you can check for the password by getting into router, or can you reset it?
I forgot my password i have a sheet that says router username and router password but they are not working
Hi Friend,
If you have forgot the password then we have to reset the router to its factory default settings so that you can re-configure the settings (since the password of your choice is not working)
In order to reset the password please follow the steps:
1. At the back of the router there is a small/tiny button (red/black), this is the reset button.
2. Push and hold this button for 30 seconds(make sure the router is turned on).
3.After 30 seconds turn the router off and wait for another 30 seconds.
4.Turn it on and reconfigure the router as per your requirements.
I hope this will resolve the issue.
Regards
Chiranjeet
Forgot my password
If you forgot your wireless password you can log into the web interface and click wireless, then wireless security. If you forgot the router password, the best solution, and this goes for all routers is to locate the reset button (usually a small pin hole on the back of the router). Unplug the router from the power supply and press and hold in the reset button with a paperclip or pen tip. While holding the reset button, plug the power back into the rear of the router and continue holding for 10-15 seconds then release. This ensures that the router is reset to factory defaults and then you can login with default username and password. Hint: usually admin is the username and the password is left blank.
3answers
Lost my password.
Unfortunately you will have to reset your router and re-set it up all again, this time write down your password & WEP/WAP key. Look for a hole at back of router remove from power and push the little button for a few seconds.
2answers
Forgot my network key password
For wireless or to manage the router?
If you forgot the wireless key password, you should be able to get into the router through a web interface and get or reset the wireless password.
If you don't remember the password to manage the router itself, it should have a "Reset" or "Go Local" button the back of the unit. Press and hold that for about 5-10 seconds. This will set the unit back to factory defaults and you should be able to log in again to set up your wireless settings.
I forgot my password for my encore router
If you are referring to the password to get in to the router page, it is admin for both username and password field.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
