Maytag Bravos MTW6600T Top Load Washer Logo
Posted on Jan 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We just had a new top-load Maytag Washer delivered. When the man finished installing it, he started a wash cycle and left. When it got to the spin cycle there was a lot of vibration. It doesn't "walk" but it is a lot of vibration. Is this normal with this type of Washer? Thanks for your help.
Anonymous
Level 3:
Guru:
  • Master 679 Answers
  • Posted on Jan 12, 2011
Anonymous
Master
Level 3:
Guru:
Answers
679
Questions
Helped
168749
Points
2165
NO. Have you checked if he installed an anti vibration pads. This is because the high frequency vibrations caused by the spin cycle can cause annoying noise and very serious long term structural damage to you home.
SPIN CYCLE WON'T START UNLESS DRUM IS MANUALLY STARTED
YOU NEED A NEW COUPLING THAT GOES BETWEEN THE MOTOR AND THE TRANSMISSION...IT'S ABOUT A $20 PART.
Maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
2answers
Front Load Washer - Error F30
hI I HAVE REMOVE THE TOP COVER. YOU WILL SEE AT LEFT A PLASTIC ACTUATOR WHO MUST BE UNPLUG FROM ANOTHER PLASTIC PIN. JUST PUT IT BACK TOGETHER AND THE PROBLEM WAS GONE!
Wont complete final spin and drain
Ok you need another repair man this is a simple timer problem since you said dial I take it as timer machine if so it has a dead spot in that cycle. although if it is a electronic control replace the control board and this will be the cure good luck and Merry Christmas
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
