SOURCE: i need the xp drivers/cd
You should be able to download the driver from the following link:
http://www.updrivers.com/drivers/Wireless_Access/Edimax/EW-7126-Windows_2000_98_XP_ME/35602.html
SOURCE: need the xp driver/cd for edimax ew-7126 wireless lan pci card
http://www.edimax.com/en/support_detail.php?pd_id=174&pl1_id=2&pl2_id=49#01
SOURCE: I need ot reset my edimax ew-7206APg but the reset button doesn't
According to the manual (which you can find by doing a search in google for Edimax), the default IP address for the device is
Default IP Address: 192.168.2.1
You can open an internet browser window on the computer that is connected to the WIRED port on the router.
In the browser window, type
http://192.168.2.1 <return>
You should be able to see the screen that is generated from the Edimax and take it from there.
Manual location -
http://www.edimax.ie/images/Image/manual/Wireless/EW-7206APg/EW-7206APg_PDg-Manual-EN.pdf
SOURCE: how can i set password
log in to your router ( with an ethernet cable attached)
type 192.168.2.1 into your browser.
Default log in details are
admin / 1234
click on security, choose WPA2 (TKIP), choose a password and then save and exit
Now remove the ethernet cable and connect wirelessly, put your password in and you should now be connected.
SOURCE: BUSCO EL DRIVER PARA EDIMAX 2.4GHz DSSS 11Mbps
Hola!
Usted puede descargar el controlador de instalacion del sitio web de Edimax haciendo clic en este enlace.
Gracias por usar FixYa.
Nota: Este mensaje se envio a traves de Google Translate. Si hay algun error, la amabilidad de perdonar.
