1- DELAY TIMER HAS A SWITCH FUNCTION THAT HAS FAILED. 2- WASH INSIDE OF BREAD MAKER WITH COLD WATER, DRY, AND TRY TO SET TIMER. 3- BREAD MAKERS ARE NOT AS POPULAR AS THEY USE TO BE, AND ARE AVAILABLE AT USED ITEM STORES FOR 15 TO 25 DOLLARS.
The error code for HHH usually means it is too hot, if it is has been used recently. If it has, unplug the machine, and try to wait for it to cool down with the lid open for about 15-20 minutes. If that is not the case, I would suggest you to contact the manufacturer at:
I don't have your manual but often these kind of alerts mean the chamber is either too hot or too cold to begin baking. If you have been baking you need to let your machine cool off with the lid open for about half and hour before starting another loaf...
That just means that your the oven chamber is too hot from the last loaf you baked in it. It does that because the ingredients have to be at at the correct starting temperature or you won't get a good rise. It's designed to do that.
However, ifIf you have let your machine cool off (open the lid and leave it open after baking for about half an hour) and still shows the HHH then you have a more serious problem and should call or contact Sunbeam.
HHH on your breadmaker means the units it too hot to begin a new batch. Stop the machine, take out the bread pan and allow the unit to cool with the cover open.
In the troubleshooting section of the manual it says that HHH indicates the unit needs to be serviced. It's got a 3 year limited warranty, so they should be able to repair it under warranty.
Please check your shaft and bushing on the bottom of your bread pan . What is happening is the bushing is dirty and binding , your drive motor is heating and resetting or stopping , I just fixed this by pulling out the shaft and lubricating it with loive oil . It works so good now , better than new !
