Check batteries in thermostat? you'll need a voltage tester,either neon light or vom.check to see if breaker is tripped.throw back and forth if it looks ok.remove cover check to see if power is getting to breaker then out of breaker.The heat is turned on with a low voltage circuit. check to see if you have 24 volts coming out of transformer.if all this checks out it gets real tricky. power to heating elements is switched via switches that are back a ways amongst lots of wires.very dangerous to work on with power on.I don't recommend trying to go further.
