Basic CD Operation:
1. Power the unit ON if STANDBY mode by pressing the STANDBY ON/OFF(#3).The default
mode is RADIO,so press the FUNCTION button(#8) to switch to the CD mode.
2. Open the CD door by pressing the OPEN/CLOSE door release button(#9).Inset a CD with the
label facing upwards and close the door.
3. The unit will read the disc and display the total number of tracks found on the disc on the
display
4. To begin playback press the PLAY/PAUSE/BAND button(#1).The first brack on the disc will
play.
5. To pause playback press the PLAY/PAUSE/BAND button(#1) once more.Pressing again resumes playback.
6. Press the STOP button(#2) to stop playback.
7. Use the AL 1/VOL- or AL 2/VOL+ buttons(13,14) to adjust the volume level. Advanced CD operation
1. Press the FWD/TUN+ button to skip to the next track.Press and hold to fast forward the
current track.Release the button to resume normal playback.
2. Press the REV/TUN- button to skip to the previous track.Press and hold to fast rewind the
Random playback
1. Press and hold the SLEEP/RDM button(#15) either during playback or in STOP mode for 2
seconds and then release.You will see the letters RDM appear on the display to indicate the
RANDOM mode in active.
2. If you enable the RANDOM function in STOP mode,press the PLAY/PAUSE/BAND button
to begin playback.If you enable the function during playback the next track will begin the
random order
3. To cancel the RANDOM playback mode,press and hold the SLEEP/RDM button(#15) for 2
seconds and release again.The letters RDM will disappear from the display to indicate the
function has been cancelled.
Repeat function
1. Before or during playback press the REPEAT/PROG button(#6) to repeat a single track
indefinitely.You will see REP appear on the display when active.
2. To repeat all tracks on the disc,press the REPEAT/PROG button(#6) twice(or once more if
you have already activated the repeat once function).You will see REP on the display blinking
to indicate the repeat ALL function is active
3. To cancel any repeat modes,press the REPEAT/PROG button(#6) once more(if in repeat all
mode or twice if in repeat once mode).The letters REP will disappear from the display.
CD program playback.
NOTE:You can only program a playback sequence while the disc is in STOP mode.
1. Press and hold the REPEAT/PROG button(#6).You will see P01 appear on the display to
indicate the program function has been initiated.
2. Use the FWD/TUN+&REV/TUN- buttons to select the track you want to play in slot No 1.
3. Press the REPEAT/PROG(#6) to store the selected track in slot 1.The display will now
display P02 to indicate your selecting the track for slot 2.
4. Repeat steps 2 to 3 for every track you wish to program up to a maximum of 20 tracks. If you
try to program more than 20 tracks the display will revert back to P01 and will overwrite the
first slot again.
5. Press the PLAY/PAUSE/BAND button(#1) to begin the programmed sequence playback.
6. Should you wish to cancel the programming you can press the STOP button to resume normal
function.
Some wireless devices simply don't have a Repeater function in their firmware, so if they are not compatible with 3rd-party firmware such as DD-WRT, OpenWRT, et al, then you can't use them as repeaters.
Is APL-4000 the model designation? Typically, units with "AP" in the model number are 'access points' which have no 'inside' to 'outside' bridge, ergo a router function in them is not possible.
If your model supports repeating function, you should be able to change mode by connecting to it with web browser and looking for "Wireless repeating Function" in there.
Repeat play (Remote control only) Press [FM MODE/REPEAT] on the remote control before or during play. The player will play all the tracks or all the programmed tracks repeatedly. " " appears on the display. To cancel repeat play, press [FM MODE/ REPEAT] again. " " disappears.
Hello and Welcome to Fixya!
Your Repeat function is Enabled.
Turn off the repeat function, the procedure to turn it off is on Page 13, of the online manualhere I guess, this would solve your Problem, If I was helpful, kindly do Rate! Regards, Waqar.
i thnk you go to the main menu, then go to options or sumthing, then you can find it there, where u can choose to repeat songs or playlists, of just plain off.
1.9GHz for the PCS Data communications and the 800MHz Band for CDMA Voice Communications. It's likely the 800MHz repeater will function for this phone, provided it is intended as a mobile phone repeater. The data functionality (web, email, mms, etc.) may be limited still, but my guess is that if you are in an area that requires a repeater, you may have limited or no PCS data service anyhow.
