Hi Most probably the projector has a broken solenoid "link" or the nylon link. This "Link" connects the slide change solenoid and the slide change mechanism. Over time this part becomes brittle & cracks, rendering the slide change non-functional. Also you have jammed the slide change mechanism. Turn the projector off. Remove the tray using the emergency release slot in the center hub of the projector. Turn the projector on and cycle it a few times in reverse, then in forward. That usually clears a mechanism jam.
Check the bellow link to read the article to have a detailed idea related to your issue:-
Please get back to us if you have further query else please accept the suggestion.
this is from the Braun site in Nuernberg, Deutschland:
HP Marketing Corp.
Tel.: 001-973-80 89 010
P.O. Box 715
Fax: 001-973-80 89 004
Pine Brook, N.J.07058
Email: [email protected]
