Question about Nokia N95 Cellular Phone
Provide support solution for N95 Nokia -- Camera/Video not functioning
When I operate the Camera function message appeared on screen is Camera module not ready & When I operate the Video recorder function messaage appeared on screen is Cam Corder module not .
Pl. let us know How to solve this problem or provide the support solution
Details of Mobile cell are as follows
Inside sticker having details
NOKIA
Nokia Corporation
FCC ID:QTKRM-180
IC-661AD-RM180
G8M850/900/1800/1900
3597525/00/355486/2
CODE:0518810
CE168
Made in Finland
Pl. let us know, is this mobile instrument is original
  • Mohit Narula Dec 10, 2008
    I have a Nokia N95. A few days back when i open to use the secondary camera which is on the main slide, it shown that UNEXPECTED ERROR OCCURED, PLEASE RESTART THE DEVICE AND THEN TRY AGAIN. Now, the main 5 megapixel camera is also not working. When I open the lens cover it goes there and comes back in a second. What is the problem? And how I can recover it? Please help me out.
    New Friend:
  • 38 Answers
Plz change your 95 8gb mobile strip because problem in your lcd jag 100% solution
Posted on Sep 10, 2011
  • 983 Answers
This happens due to the firmware problem(this occurs due to virus attack) ....
try giving the restore factory settings in your phone ...
if you still persist the problem then you just update the firmware of the phone that solves your problem ....
you can update the firmware with the normal datacable only ...
you can update to the latest firmware for your phone from the software called" Nokia Software Updater "...
you can download this for free from the website of nokia directly given below :
http://europe.nokia.com/A4579163
(your pc must be connected to net to download the latest firmware)
butremember dont disconnect the cell while updating the firmware is inprocess if you do so your phone will be severely damaged you can neveruse your phone ...
even the manufacture can t help with this if you interrupted during the firmware update ....
after you update the firmware all your problems will be solved ...
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Posted on Jul 13, 2008
6ya staff
SOURCE:
How can me format my mobile telephone ? (Nokia N95 8GB)
How to Format Nokia N72, N73, N81, N95, NSeries Mobile Phones. Method 1: Three Finger Reset for Nokia Phone1. Switch off your Nokia phone.
2. Hold down the following three keys, Green (call answer button) * Key, and Number ‘3? key.
3. While holding these buttons, press the power button and switch on the phone.
4. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message.
Method 2: Hard Format of Nokia Mobile Phone1. Switch off your Nokia phone
2. Now Press following key sequence *#7370#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button and switch on the phone.
5. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message.
Method 3: Soft Reset of Nokia Mobile Phone1. Switch off your Nokia phone
2. Now Press following key sequence *#7780#
Please Note: The Above Nokia Phone Formatting method will erase all your Phone data. So do backup before proceeding for Formatting
May 17, 2010 | Nokia N95 Cellular Phone
95 8gb camera preoblem
It might be a minor bug no worries, try using camera without inserting mmc if this doesnt works try formatting ur phone to factory settings if even this doesnt works try upgrading your phone to newer version If all of the above dont work there is hardware problem and u might have to give your phone at nokia care{service center}
Feb 20, 2010 | Nokia N95 Cellular Phone
My nokia n95 8gb camera is not ready
format ur phone
Enter the code: *#7370# and press Yes to confirm initialization.
Jan 27, 2010 | Nokia N95 Cellular Phone
Nokia n95 mobile- can only use with loudspeaker on hand set speaker does not appear to function
try a reset the code is*#7370# if this fails take it to a nokia care point back up your contacts and images before you reset thre security code is 12345 if asked
Jan 01, 2010 | Nokia N95 Cellular Phone
The camera light is always ON even after switching the phone OFF.
better check out your firmware or take it to a neraby specilist
Sep 15, 2009 | Nokia N95 Cellular Phone
My nokia n95 turn to white screen.
Power off phone. Press and hold Green, * and 3 and keep them held whilst powering on and for a few seconds after
man the code written is hard reset for n95 **** .there is a hardware problem in the cell phone you need to change the strip of ur cell phone which connect the upper and lower portion.
Jan 30, 2009 | Nokia N95 Cellular Phone
Nokia TV-N100
if there in cell memory card remove it
and power on cell
restore cell go to
if you know password type and restore cell
and format your memory card r remove extra folder
if you have not password you can ask me 4 password
Jul 09, 2008 | Nokia N95 Cellular Phone
Camera Problem
remove the camera and put it back it will be done 1000000% ok
May 29, 2008 | Nokia N95 Cellular Phone
Help needed on N95 8GB
This problem is from your keypad Ic, Possibly it is working automatically. You need to change Keypad IC and then software re-install.
May 12, 2008 | Nokia N95 Cellular Phone
Camera does not work
I am having this same error message appear on my phone but this is not the camera its the messages on mine, i can't send or recieve any messages. Suggestions have been made to me that i do a master reset on my phone so you could always try the same thing. Everything will be wiped from the phone so make sure to back up files you want to keep.
Apr 01, 2008 | Nokia 6288 Cellular Phone
Nokia N95 Cellular Phone Logo
255 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
