I disagree. The procedure is so easy no Service Manual is needed
1) Remove ALL power. Remove the AC adapter, and Battery.
2) Open the laptop.
The plastic frame in front of the LCD screen is the Display Bezel. (Gateway? Believe they call it the LCD Panel Bezel)
Down in the BOTTOM corners, next to the Hinges, are screws to be removed. One in each bottom corner.
There are Screw Covers over these screws. The Screw Covers need to be removed. Little round covers I believe to be made of plastic. (Some models they are made of synthetic rubber)
I use a computer pick to Gently remove them. Some use the tip of an X-Acto knife. I do not recommend this as there is a possibility of injury. Perhaps a large darning needle. (Needle you sew with, but is Large in size)
Pick up at one edge of Screw Cover. Screw Covers are held on by a type of rubber cement. I LIGHTLY stick them to the Display Bezel for safekeeping.
(Yes. They like to stick to the tool, your fingers, and it seems passing jets in the sky. If you are careful with them, you should be able to reuse them. If they do not stick anymore, use a toothpick, and apply a TINY dab of rubber cement to them/it )
Once the Screw Covers are removed use a No.1 Philips screwdriver, or equivalent Jewelers screwdriver; to remove the 2 screws.
The Display Bezel has TABS going around the exterior perimeter, of it's inside edges. These Tabs snap into matching LATCHES on the Display Cover.
You can come from the Outside edge, where the Display Bezel meets the Display Cover, and use a thick guitar pick.
The guitar pick is wedged into the parting line, of where the Display Bezel meets the Display Cover.
Once a 'crack' is formed in-between the two, then the fingertips are used to gently start popping the bezel from the cover.
You slowly go along with your fingertips, and work along the top, then sides. By the time you have both sides almost loose, the Display Bezel usually pops off.
I like the flex method. Come to the inside edge of the Display Bezel. Where it meets the LCD screen. I suggest start on the Right side/Middle.
Use a fingertip, and lift up the inside edge of the Display Bezel up a little. Can't lift up at that spot? Move over. You are at a Tab/Latch.
With this spot lifted up a little, use the fingertip of the other hand, and slide under next to it. Now use your fingertips as wedges, and pop the Display Bezel loose a little at a time.
I start at the Right side/Middle as stated. Left hand fingertips go DOWN the right side, Right hand fingertips go UP the right side. Then I go across the Top, and down the Left side.
MOST of the time, as stated; the Display Bezel usually pops off when right side, and left side are most of the way popped loose. NOT always though!
Sometimes you have to pop EACH and EVERY Tab/Latch loose.
Also; watch around the Hinge area/s. Display Bezel can get hung up around them. Go slow, and gently work the Display Bezel off, around the Hinge areas.
Display Bezel popped off, sit back; relax. You just did the hard part. Wasn't so tough, huh?
This is what the Display Bezel looks like removed,
The MAIN view shown is a BACK view. In the smaller views underneath, the 4th view from the Left, shows the FRONT view.
If you SET your mouse cursor in the middle of the Main view photo, the Zoom In feature is enabled. You can CLICK on any of the smaller views, to make them appear as a Main view.
You can also see that the Hinge Covers, are an integral part of the Display Bezel. Shows you that when removing the Display Bezel, these Hinge Covers may need to be worked off of the Hinges.
Of course, may not; as I have previously stated.
The LCD screen is an Assembly. It is composed of layers. These layers are kept in the factory set alignment, by a metal Screen Frame. The Screen Frame resembles a picture frame.
There are THREE screws on each side of the Screen Frame. These screws (Philips) go through metal Brackets, and hold the LCD screen/Screen Frame; to the Display Cover.
On EACH side, there is 1 screw towards the Top, 1 screw towards the Bottom/Middle, and 1 screw towards the Bottom.
Remove all 6 screws.
At the Top is the Webcam Cable. Unplug it from the Webcam Module. (Cable pulls to LEFT side, facing laptop)
The TOP of the LCD screen is now tilted forward. The Video Cable plugs into the Bottom side.
There should be a piece of clear Mylar tape, holding the Video Cable connector in place. Carefully peel it back, unplug the Video Cable from the LCD screen.
Remove the LCD screen.
Reverse steps to install new LCD screen.
For additional questions please post in a Comment.
A replacement screen maybe available from this WEB site. www.lcdparts.net
The screen is removed by undoing the hinge screws, careful unclip the video connector from the motherboard.
Keep the screws together as you remove them so you will know which screws are needed to install when you fi the new LCD screen
Undo the screws that hold the bezel that surround the LCD screen, then
remove the bezel (it may be also held in place with double sided tape).
When the bezel is removed the LCD screen is secured to the hinge assembly by more screws around the edge of the LCD screen.
When you install the new LCD screen, reverse the order you took in removing the LCD screen.
These WEB sites may assist you in repairing the LCD etc.
Replacing Display hinges
No, Remove the Screws On the Front Bezel Of the Screen.. (there should be 4 One on each corner), Then you will need a thin plastic tool such as a guitar pick or thin credit card... Pry the front plastic bezel from the back cover starting at the top right corner.. THe Whole Front Bezel Is Held On By Snap Down Plastic Tabs... You Will Need To Slide The Plastic Tool Along The Entire Top Of The Screen At an Angle... Then Once the top is insnapped, Do the sides, Then The Bottom.. Front Bezel Is Now Off And You Should Have Full Access To The Display...
You will have to Unscrew the screen from the Hinges On THe Left And Right Sides... Usually 2 or 4 screws on each side then screen is removable
Check out page 86 for the display schematics. Page 120 outlines the dis-assembly. Page 154 actually describes the screws of which you speak. You may be able to purchase them locally.
The laptop screen is secured to the laptop with screws at the hinges. There are usually two screws per hinge. The LCD screen has one ribbon cable and possibly a power connector for the back lighting attached to the motherboard near the hinges. Disconnect these before you lift the LCD off the base, they are under the plastic panel above the function keys next to the hinges.
I can give you some general advice. I haven't worked on your particular model, but I can help guide toward what you want to do. To remove the LCD screen, you have two main goals: 1) disconnect the signal cable and 2) remove the LCD screen at the hinges. Depending on the model, you will need to remove the cover between the keyboard and the hinges, the hinge covers, and perhaps the keyboard too. The ribbon cable that connects to the LCD matrix is under that cover between the keyboard and the hinges. The cover also covers up the screws for the hinges. Get to that LCD and unplug it first; then remove the screws for the hinges. The voltage inverter that jacks the +18 volts up to +600 volts for the screen backlight is usually either under the cover above the keyboard or behind the bezel beneath the screen. Good luck!
Hello Wendy names Nick and just done hinge work on the Presario V5000z and readin up on your problem my suggestion would be lookin on ebay or various sites for the hinge then go about replacing it.
Steps involved in replacing the hinge start with removing power and battery
Next come the more difficult step, removing all the screws fron the bottom of the unit (this is done to gain access to the wireless cables which run from the wifi card to the lcd display)
once the base is removed then you carefully use a flat head screw driver an near the top row of keys (while pressing a few of them down) you will see a few notches which you can pry off the top cover giving you access to the lcd screen connector and bracket anchoring screws.
hopefully you disconnected your wireless antenna leads by now, and also disconnected the lcd cable from the board.
now you have the lcd display free from the base, now to change the hinge.
under the lil rubber circle pads are screws holding the brazel to the front of the lcd, this should be removed to get access to the lcd itself and thus the hinge brackets.
remove replace carefully i might add. then do everything in reverse to get the system reassembled and there ya have it
hinge has been replaced
P.S. careful steps should always be taken to prevent shock damage to any computer system when working on internals, also mind bending and pincing cables since they can most times be easilly damaged
there are plastic covers over the hinges, which may be part of the faceplate. being a compaq the hinge screws are most likely torx head screws. compaq used to make a special tool for removing the plastic covers on their laptops. the tool was a bar with a piece of fiberglas circuit board embedded in it. you insert the circuit board into the groove between the top and bottom covers and twist. this is, of course after removing all of the cover screws. some of the cover screws on the display may be hidden under rubber bumpers.
