Belkin (F5D7230-4) Router (587009) Logo
Posted on Jan 12, 2011
I baught a new Sony EX715 TV with a Sony UWA-BR100 USB WLAN adapter to connect the TV to the internet. The connection fails with error code 2200. According to Sony it would be an issue with the router. The TV gets an IP address, seems to be connected to the router but has no connection to the internet. Any idea? Thanks Bernd
5 Related Answers
rickyostrom
Ricky Ostrom
  • 274 Answers
  • Posted on Dec 01, 2008
SOURCE: Belkin wireless G router not connecting PS3
The PS3 should find the SSID of the network, or you could enter it. And then enter the encryption key, be it WEP or WPA. Everything else should be automatic.
Anonymous
  • 1214 Answers
  • Posted on Feb 16, 2009
SOURCE: Connection Failed
First, have you done a master hard reset of the router by depressing the hidden button on the back of the router?
2nd, what Operating System are you running?
Reply back and I can give you more information/instruction.
Anonymous
  • 700 Answers
  • Posted on Apr 01, 2009
SOURCE: Belkin Wireless Router F5D8633-4 does not connect to the internet
Try first to connect to the internet using wired connection. If it connects, try to connect on wireless make sure the router is broadcasting signal.
Anonymous
  • Posted on Jun 12, 2009
SOURCE: Belkin Wireless N router/Embarq 660 modem/No internet
THE PROBLEM IS THAT THE BELKIN RTR AND THE 660 HAVE THE SAME IP ADDRESS THE QUICKEST FIX IS TO RENAME THE LAN IP ADDRESS OF THE BELKIN RTR
Anonymous
  • 108 Answers
  • Posted on Jan 15, 2010
SOURCE: Belkin F5D8236-4 Wireless Router will not connect
1) With direct connect with modem, check the IP address and default gateway.
(I came across such a modem, it gave default gateway as 192.168.1.254)
I also had the doubt of configuring as a dynamic connection
But it won't work!
Contact your ISP to completely bridge the modem and configure the dsl modem as PPPoE connection with correct username and password.
Finally connect the modem to router and do a complete network power cycle, i.e.: Unplug power from router 1st, then power from modem, unplug the telephone line and now do the exact reverse process... Plug back the tel. cable, then power to modem... now WAIT for lights on modem to come back, then plug in the power to router. This will surely work.
Sony UWA-BR100 windows 7 driver
Go to Sony support.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
29helpful
3answers
How to use Sony UWA-BR100 USB Wireless LAN pc
Hi
Required drivers can be downloaded from this program: Driver Update Software. Have a nice day
Peter
1helpful
How do i connect my laptop to sony bravia using UWA-BR100 ?
Connect the Laptop and TV with a *CROSSOVER* ethernet cable and then enable "Internet Connection Sharing" on the Laptop's "Wireless Network Connection".
To enable "Internet Connection Sharing", open the Network Connections folder ("Start > Run" type NCPA.CPL and click OK). Right click the Wireless Network Connection, select Properties and then the Advanced tab [XP] or Sharing tab [Vista]. Tick the box "Allow other network users to connect through through this computer's internet connection.
Just brought a Sony Bravia HX 800 and added a wireless LAN adapter (UWA-BR100) to get Internet TV. After network set up NOT able to access internet. Message reads Wireless device OK Local Access FAILED...
Hi
I got the Bravia KDL-40EX713 and the uwa-br100 I had massive problems getting it to work with a BT home hub. Eventually I found manual setting that work. Firstly I logged on to the router and went the the advanced settings bit, then I went to the DHCP table that shows all the devices connected. I picked an unused Ip address from the range of existing ones being used (this sort of thing 192.168.1.73)
I then used the following settings for the other fields (I don't think the secondary dns setting is right but it still works)
ip 192.168.1.73
sn mask 255.255.255.0
default gateway 192.168.1.254
primary dns 192.168.1.254
secondary dns 192.168.22.23
If the DNS server ip is wrong then you get local access OK but internet access failed.
Hope this helps.
Ian
10helpful
2answers
Need UWA-BR100 drivers
When I install de UWA-BR100 driver with the fix mentioned above it works but it does not show all wireless networks available. When I look at the hardware properties I see 802.11b Preamble and a mention of Adhoc 11n.
When I look at the properties of my other wireless adapter there is mention in the properties of: 802.11n 20 MHz, 802.11n, 802.11n modus, Adhoc Qos, Adhoc 802.11b/g. This adapter shows more available wireless networks then when I use the UWA-BR100. With the UWA-BR100 I can not see my own wireless network.
Does anyone has a solution for this problem?
Thanks
Sandra.
1helpful
I have the Sony KDL60EX700 and the Sony UWA-BR100 wireless adapter. The adapter see's my router and has a strong reception (5 bars) but fails on Local access and Internet access. What to do?
I have had this EXACT problem (same models). Turning off the router and letting it restart get the TV going.
Once it is up it will some time loose the internet, and I have to restart the router.
I am working with Sony Support one this issue.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
