For most Microlife blood pressure monitors, the error 3 indicates that the unit cannot reach the proper pressure in the cuff to start the test. If replacing the batteries doesn't work, check that the cuff is properly plugged into the socket on the monitor. Next you may need to replace the cuff. There may be a leak in the cuff or the hose between the cuff and the socket. Microlife sells replacement blood pressure cuffs here: https://www.microlife.com/consumer-products/blood-pressure/cuffs-and-supplies . These cuffs fit all of their devices except for the wrist versions.
i have micro life bp aparatus since 3 years but from last month it diosent work good every attampt it indicates low blood presure at all on screen it dosent go up by 140 and all the time it shows 90 / 50 please advise what to do
Best BloodPressureMonitors ' Reviews
What's the best BloodPressureMonitor? ConsumerSearch recommends Home BloodPressureMonitors based on reviews.
www.consumersearch.com/blood-pressure-monitors · Cached page
BloodPressureMonitoring at Home -- familydoctor.org
Ask your doctor or nurse to teach you how to use your bloodpressuremonitor correctly. Proper use of it will help you and your doctor achieve good results in ...
familydoctor.org/online/famdocen/home/common/heartdisease/treatment/128.html · Cached page
Digital Home BloodPressureMonitor ' Arm ' Meter ' Cuff
Southeastern Medical Supply for the best Digital Home Arm BloodPressureMonitors including Automatic, Digital, Electronic, High, Manual, Wrist, Arm BloodPressure ...
www.semedicalsupply.com/Arm-Blood-Pressure-Monitor-Arm-Meter-Cuff-s/73.htm · Cached page
bloodpressuremonitor ' eBay
2,547 results found: Digital Wrist BloodPressureMonitor & Heart Beat Meter · Sunbeam Automatic Digital BloodPressureMonitor · Digital Wrist BloodPressure ...
shop.ebay.com/i.html?_nkw=blood+pressure+monitor&_dmd=2&_frs=1&_trksid=p3286.c0.m359 · Cached page
Home BloodPressureMonitor ' Wrist ' Meter ' Cuff
SE Medical Supply for the best Home BloodPressureMonitors including Automatic, Digital, Electronic, High, Manual, Wrist, Arm BloodPressureMonitors and more.
www.semedicalsupply.com/Home-Blood-Pressure-Monitor-Wrist-Meter-Cuff-s/51.htm · Cached page
Home bloodpressuremonitors provide a quick and easy way to monitor your bloodpressure in the comfort of your own home and we aim to help you find the best home blood ...
thebloodpressurecenter.com · Cached page
BloodPressureMonitors - bloodpressuremonitor, omron ...Bloodpressuremonitors - portable wrist models, models with printers, heavy duty floor models and digital bloodpressuremonitors from Omron, LifeSource, VSM MedTech ...
www.healthchecksystems.com/bloodpressure.htm · Cached page
bloodpressuremonitor ' eBay - Health Beauty ' eBay
DIGITAL BLOODPRESSUREMONITORM- PRESSURE AUTOMATIC ... Amounts shown in italicized text are for items listed in currency other ...
health-beauty.shop.ebay.com/Health-Care-/67588/i.html?_nkw=blood+pressure+monitor&_frs=... · Cached page
I AM GETTING ERROR 3 ON MY LIFESOURCE BLOOD PRESSURE MOINTOR 7 WHILEPUSHING ON START BUTTON,IT DOES NOT GO AHEAD MORE THEN FIGURE 2 & COMES BACK TO 1 & THEN SHOWS ERROR 3,CAN ANYONE,SUGGEST OR GIVE SOLUTION/REMEDY ON MY MAIL ID:[email protected] I HAD LOST OPERATING MANNUAL & WARRANTY CARD,ALTHOUGH THIS MONITORING INSTRUMENT'S HAVING LIFE TIME WARRANTY,INCLUDING CUFF. THANKING YOU. H.M.PANDYA.
Wrist blood pressure monitors must be used with the arm above heart level. You can do the pledge of allegiance while doing a reading to make sure this is done. Usually this error occurs when inflation takes too long or the placement of cuff is wrong.
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Try different locations. The sensor must be over a vain to pick up the pulse. Locate the point on the cuff where the sensor is, and place this over the elbow. That should work. Good luck.
