HOW TO FIX MY PRINTER, IT DISPLAY A GENERAL ERROR, AND BOTH RED AND GREEN LIGHT IS BLINKING.PLS HELP ME..TNX
Epson t13 is blinking the orange light
My epson t13 printer follows the general error
some forighn objects inside the printer please remove it then start print
Your printer need to be reset.
http://tech911.biz/website/index.php/printer-resetter-softwares/82-epson-t13-reset-software
GINAWA KO NA LAHAT UNG ANJAN SIR.. PATI UNG DINOWNLOAD WLA P RIN PO.. blink pa rin ng blink.. ayaw n mamatay ung printer at. d na rin gumagalaw ung mga cartridge pag nag on
SOURCE: my epson stylus t13 have
Hello there,
This is called a false paper jam. normally, a reset is required for this.
Hold the power button for 30 seconds and this should prompt a shut down.
next, make sure that the rollers are clean inside. use a lint free sloth and some distilled water. Dampen the cloth (Q-tips works fine too, please do not use cotton) and rub the rollers.
Then as it dires up. turn the printer on and do a test page.
Please don't forget to leave a feedback and testimony if it works.
SOURCE: epson stylus T13 general error
based on my experience my printer show general error every time I print when the printer is about to load paper.. so i check out the loading and found out that part of it was damage and fall off, i don't know what to call it, but it looks like a hook of some sort.. maybe for triggering the loading mechanism that's why my printer give me error everytime it's about to load paper.
So, my advice is to look inside your printer and see if there are foreign object or fallen parts.
SOURCE: GENERAL ERROR IN EPSON STYLUS T10
Probably the waste ink tank is full.Try to do this:
First of all download http://www.mediafire.com/?hzxbdhkzxv9.Extract to your C drive. Run indoreset.bat, then follow the instructions.
After that right click AdjProg and select properties. Go to compatibility and select Windows XP.
Click OK at the bottom then right Click AdjProg and select run as administrator (if you have this
option). When working accept the agreement and go to
1. Particular adjustment mode,
2. Then waste ink pad counter,
3. Click Check
4. Tick both boxes.
5. Then initialization.
6. Then it's done.
