SOURCE: Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
SOURCE: cold water will not flow into machine
either the valveis faulty or the dispenser box is blocked, remove the internal hose from the valve anf see if you have full pressure at that point if yes box is blocked. Regards Advisor
SOURCE: tap will not turn off on hot water supply to
try loosening the nut just below the handle with a crescent wrench, assuming it is not a push pull valve. turn it a half turn counter clockwise and then try turning the knob. if you a different type faucet let me know so I can tell you how to turn off. you can shot off the hot water heater control valves on top of the hot water machine to keep from losing as much water be careful when turning handle use rag in case the valve breaks. You may want to sprat a little WD-40 on it first, hope this helps.
SOURCE: GW52F Fisher and Paykel Washing Machine
you should check new washing machine..i know a effective site..
http://www.washingmachineadvisor.com/
SOURCE: Hi Guys, My machine will only wash in HOT water.
The first thing to check is the water inlet screens. Turn the water off and remove the cold water hose from the washer. There is a screen in the valve that keeps sand and debris out of the valve. You can remove the screen and clean it, then flush the hose in a bucket to get any remaining sand out. Reattach the hose and try it again. If that does not work the problem could be one of several things. From the fill valve to the electronic control. Hope that helps
Testimonial: "Thanks so much! Will try it this weekend. "
