Emergency steps:
Turn electric power off.
Release tank pressure by opening bathtub faucet on hot side.
Turn off water supply to heater.
You can turn water heater ON for short periods (1/2 hour) to make some hot water until repairs are made.
It sounds like runaway heating caused by shorted element, possibly caused by leaking water. But I cannot tell for certain what the problem is. Read following links and/or call plumber.
http://waterheatertimer.org/Leaking-water-heater.htmlhttp://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.htmlOver-amping:
Look at watt rating label on side of tank.
For example 4500 watt water heater requires 30 amp breaker and 10 gauge wire.
If you have 20 amp breaker and 12 gauge wire, then change elements to max 3800 watts. Tank will heat more slowly.
You have to fix leaks, and I cannot see that problem. Call plumber or repost question with clear description of leak.
If you need further help, I’m available over the phone at
https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
