ViewSonic VX2235wm LCD Monitor Logo
Posted on Jan 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Could you please let me know if i can use my viewsonic monitor as a tv if so what cord do i need to get
Anonymous
Level 3:
  • ViewSonic Master 32,281 Answers
  • Posted on Jan 12, 2011
Anonymous
ViewSonic Master
Level 3:
Answers
32281
Questions
Helped
7907933
Points
102259
The monitor does not have a built-in TV tuner and cannot function as a TV unless your computer has a TV tuner. In this case all you need to do is connect the monitor to your computer and start the TV tuner/program in your computer.
I am looking for a power supply cord for a Viewsonic VG710s monitor. Thank you
The power cord can be found at, a computer store, tv repair shop, or Radio Shack
My monitor is ViewSonic VX724 17" LCD Monitor, when it is turned on, the green light keeps flashing and also the screen. I've checked the computer, cable and power cord, they seem fine. What is the...
Look for bad caps on the board first:
http://www.badcaps.net/forum/showthread.php?t=12510
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Can i use a power cord from a dell moitor i tried but i dont know if its the cord or moitor it was give to me without cord
It uses the same power cord as your PC, NEMA5-15P to IEC C13,
User manual:
http://www.viewsonic.com/assets/027/7939.pdf
It may have problem inside. See failed VIEWSONIC in my albums.
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
1helpful
Can't get the monitor to come on
The same power cord as used for your PC power supply cord.
Email me if you need user manual, [email protected]
I hope there is no problem with this TV, it has known problem with power supply and sound problems.
http://s807.photobucket.com/home/budm/allalbums
3helpful
2answers
Where can I get a power cord for the ViewSonic VE700 LCD Monitor
Hello there:
Most of the computer stores or a electronics store like office depot or radio shack or walmart or k-mart ect ect ....will have these cords
Furthermore if you have a second hand store in your area they might have them there too
Hope this is very helpful for you>
Best regards Michael
2answers
LCD monitor (viewsonic va720) "No signal"
You will need to disconnect the VGA cord that is connecting the monitor to the hard drive. Once you have that disconnected, try attaching another cord to determine if the cord is the issue. If you dont have another cord to test, then you will have to purchase another one from your local computer parts store and attach to determine if that is the issue you are having.
If the cord does not work, then you will have to take your monitor into a repair shop as there maybe an issue with the receiving port on the monitor.
I hope this was helpful and thanks for asking the experts.
1helpful
ViewSonic VX2235WM turns on than screen goes blank changed power cords cable cords viedo card cpu still same problem
The problem is most likely the monitor itself. Hook up an old monitor (usually someone has an old monitor laying around) if the computer works with another monitor you'll know for sure.
Look at your monitor using a flash light at an angle, if you can see a picture in the background you have a bad inverter.
My viewsonic monitor works fine for some time but the n suddenly stops displaying even though the power cord is fine ...after some time it comes alive or some times by fidgeting with the power cord.....
It sounds like a loose connection. The easy thing to try is to replace the power cord to make sure that's not the problem. If that doesn't fix it, it's probably a broken or loose wire inside the monitor that you would need to trace down with a multimeter.
Top ViewSonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
