there is problem with your hard disk. your hard disk wire may be loose. try to remove and refix all sata wires of your hard disk. "operating system not found" message may be coming because you may have not installed any os (windows, linux or mac) in your notebook. try to install operating to system to fix this. there may also be proble with your hard disk, your hard disk may be dead. if your notebook is showing message "operating system not found" without any reason then you may have put your notebook in high magnetic field area. due to high magnetic field, sometimes hard disk's are formatted automatically.
getting the error "operating system not found" means that the hard drive where the Operating System is installed (i.e. Windows XP, Windows Vista, Windows 7), Cannot be found by you BIOS upon the boot sequence.
When you turn the PC/Laptop, you normal see a screen that flashes flashes with screen that displays the ff:
I recommend going into your BIOS and making sure your system is detecting the hard drive(s). If not, recheck your cable connection at the drive and the board. If it is detecting the drive, make sure it is set to be one of the boot drives(I would make it 2nd to the CD-ROM) and reboot your server. If you get the same error, you will need to reinstall the os. Good Luck C2Solutions
