SOURCE: Problem with Windows XP recognizing Creative Sound Card
It sounds like a software problem. Though you did the right thing by entering the bios & disabling the onboard sound. That should have been enough. Did you uninstall the old intergrated sound drivers before adding the 24bit card? Just about all the drivers & upgrades for your 4600 through Dell is Creative software & thats why your having a tough time. I would put everything back to how it was. Re-enable the intergrated sound & reboot! Run system restore & check that every thing is running right!! Look at this dell web site for the sound drivers you have at this link:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=
If you must, install a upgrade for your intergrated sound. Just so you can uninstall it after a reboot. Re disable the sound in the bios. Do not install your new card yet. While back in windows device manager you should be missing a PCI device. Shut down install the new sound card. Hopefully windows will want the drivers & all runs fine. If still no it could be a bad card (i know what your thinking but it's possible). The only thing left is the regestry is using the wrong PCI device.
well the ports on the card could be shot and the card might have been installed by a person with a static charge built on thier hands without them knowing, which can cause the card's electronics to fry and be ALMOST completely disabled. try using a different mic or taking the card out and re-installing it.
SOURCE: How to connect 5.1 speakers to a notebook
yes it will :) if it has 6 female ports (the normal 3 + 3 extra) it will work just fine :)
SOURCE: Casio ctk-496 claims to be midi keyboard controller
Try downloading MidiOx and troubleshooting with it. It will show you if you have any midi activity and which channel your Casio is transmitting on etc.
SOURCE: creative labs sbo 130 sound blaster extigy.
You can download your driver from the following links, all the best, try it, reply me
at [email protected]
http://www.lostmydrivers.com/driver/download/18835/Creative/Soundcard-Drivers/CREATIVE-SOUND-BLASTER-LIVE-24-BIT-AND-SOUND-BLASTER-AUDIGY-LS-DRIVER-1.04.0055-FOR-WINDOWS-XPWINDOWS-XP.
http://www.lostmydrivers.com/driver/download/19474/Creative/Soundcard-Drivers/CREATIVE-SOUND-BLASTER-X-FI-SERIES-DANIEL-K-SUPPORT-PACK-2.0-WINDOWS-XP-2003-VISTA-2008-WIN7-2.0-WINDOWS-XP-2003-VISTA-2008-WIN7.
